Cylinder #1 Not Running - Got Spark/Fuel/Timing - Pull Plug Up And Its Perfect? Why?
Old May 10, 2006 | 12:19 PM
PINKS's Avatar
I want a CRX tattoed on my butt
Default Cylinder #1 Not Running - Got Spark/Fuel/Timing - Pull Plug Up And Its Perfect? Why?
Watch these 2 vids
http://media.putfile.com/sparkwire
http://media.putfile.com/sparkwire2
Car is a d16a6 obd0 brand new engine with some internal work done to it
I thought it just sounded choppy at idle but when I drove it yesterday it sounded like a bike
Well just now I pulled the spark plugs one by one and 2-4 almost cause the engine to stall out and die, pulled the #1 plug and nothing happened
<FONT SIZE="20">BUT</FONT>
When I was slipping it back in I heard the engine noise grow, clicked it into place and it went back to stutterring
So I pulled it back out a bit, maybe 3/4" and the cylinder starts firing!!!
WTF
So I put in a set of known good magencore wires and it did the same thing, you cna pull it out a bit and the motor sounds mint, sounds perfect, plug it into place and the cylinder stops firing, for 2 sets of wires
WTF would cause this?
I'll post a video in a second
Modified by PINKS at 1:47 PM 5/10/2006
Old May 10, 2006 | 12:34 PM
stocker2shocker91's Avatar
I requested a short story for a title.
Default Re: Cylinder #1 Not Running - Got Spark/Fuel/Timing - Pull Plug Up And Its Perfect? Why? (PINKS)
sounds kinda like a burned valve to me
i have a civic in my driveway with the same problem but ill wait to the vid for further conclusion
Old May 10, 2006 | 12:43 PM
PINKS's Avatar
Default Re: Cylinder #1 Not Running - Got Spark/Fuel/Timing - Pull Plug Up And Its Perfect? Why? (stocker2sh
How the hell would a burnt valve only allow to ignite the cylinder when you pulled the spark plug up?
The valves are brand new
vid coming in 2 min
Old May 10, 2006 | 12:44 PM
guess
im confused
Old May 10, 2006 | 12:47 PM
PURPLETERROR aka BIGMATT's Avatar
change the plug
PINKS's Avatar
Watch these 2 vids
Old May 10, 2006 | 09:28 PM
StorminMatt's Avatar
How about running a compression test to confirm? Also, if wierd stuff is happening with the plug, try changing the plug.
cagarcia14
Apr 23, 2013 05:34 PM
PINKS
10
May 10, 2006 05:19 PM
senbei
Jul 1, 2003 03:19 PM
_Endless_
Aug 16, 2002 11:42 PM
