engine vibrations = bad balance shafts???
my engive vibrates a lot and i thing is from bad (or wrong intalation of) balance shafts, so is there anything i have to check to find out if its from balance shafts or not???
My motor mounts looks ok and my timing must be fine cos the motor runs and idles REALLY GOOD... so?? anything else i have to check for?
$th gen H22A btw...
$th gen H22A btw...
You can check the rear shaft by putting the engine at TDC and seeing if the shaft is in the correct position through the alignment plug on the back of the block. To check the front shaft I think you'd have to take a few things off to see the alignment marks. Refer to the helm manual...
PreludeBC420
Aug 23, 2016 03:00 PM
k2p2
Feb 1, 2010 08:15 PM
G2IntegraGS
May 10, 2009 05:26 PM
