Clutch
Old May 10, 2006 | 11:05 AM
compprat's Avatar
Default Clutch
ok this is kind of a stupid question but i just want to make sure.
I have an 88-89 ZC DOHC zc engine, and im running my stock dx tranny. When i search for a clutch do i look under 88-89 civic, or 88-89 integra? most of the parts for this engine come off of an integra so i thought i might ask. Also where can i find an si tranny?
Old May 10, 2006 | 02:17 PM
yellowrexsi's Avatar
Default Re: Clutch (compprat)
you have to use the one that matches the flywheel.
Old May 10, 2006 | 04:00 PM
compprat's Avatar
Default Re: Clutch (yellowrexsi)
so the it doesnt matter what engine you have, its the tranny?
Old May 10, 2006 | 04:43 PM
The flywheel is on the motor, the clutch has to bolt to that. So the other way around.
Old May 10, 2006 | 04:51 PM
jlicrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by compprat &raquo;</TD></TR><TR><TD CLASS="quote">ok this is kind of a stupid question but i just want to make sure.
I have an 88-89 ZC DOHC zc engine, and im running my stock dx tranny. When i search for a clutch do i look under 88-89 civic, or 88-89 integra? most of the parts for this engine come off of an integra so i thought i might ask. Also where can i find an si tranny?</TD></TR></TABLE>
all of the parts below the top of the block (except timing gears) on the DOHC ZC are same as 88-91 CRX/Civic Si D16A6 - most of the parts above the top of the block are the same as 88-89 Integra D16A1 - clutch and flywheel is the same as CRX/Civic - the clutch you need is first determined by the year of the transmission - 88 transmissions have different spline count on the input shaft - once you determine year of transmission, the clutch you need is further determined by the year of the flywheel - 88-91 flywheels use 200mm diameter clutch and 90-91 flywheels use 212mm diameter clutch
Old May 10, 2006 | 09:45 PM
compprat's Avatar
OUTSTANDING thanks guys, im a scrubb
johnpowellcrx
Oct 5, 2004 09:23 PM
phatrick2332
Mar 31, 2004 06:11 AM
cr-x si
Jun 22, 2003 12:49 PM
FourthGenHatch
11
Apr 16, 2003 06:43 PM
brusk
Jun 5, 2002 08:53 PM
