**WHAT FAN WILL FIT LS TURBO REX??**
Old Apr 10, 2002 | 07:09 PM
EF8SIR's Avatar
Default **WHAT FAN WILL FIT LS TURBO REX??**
whats up everybody??
right now i have a 97 b18a in my rex with a greddy turbo on it, i need to throw a fan on it since i have no fan right now! it just wont fit!! so i can get fal fans from my work, but they dont make them for crx's! what will fit?? they make 92-99 civic fans and integra, will any of these work?? or any sugestions on a fan that will work?? maybe from junkyard or somethin??
thanks!!
geoff
Old Apr 10, 2002 | 07:43 PM
Smoothy's Avatar
Default Re: **WHAT FAN WILL FIT LS TURBO REX??** (EF8SIR)
Use a pusher fan instead of puller.
Old Apr 10, 2002 | 09:57 PM
echo999's Avatar
New User
Default Re: **WHAT FAN WILL FIT LS TURBO REX??** (superfastCRX)
I actually looked around...
When my radiator busted, and when I got a Fluidyne, none of my fans would fit anymore. I actually ghetto rigged it so I ran the A/C fan in the spot where the
radiator fan was. Yesterday, I bought 2 Hayden (no name brand) fans from a parts store, and test fitted them. They both had 2.5" max depth. Again, the A/C fan didn't fit still. The FAL fans won't help me either since they are 2.5".
So to answer your question, unless you can run a pusher fan (which I couldn't),
You might try SPAL. They have some high flow fans at 2.05" depth. These are the
thinnest that I've found so far. IF ANYONE has found any other fans that are
thinner, please disclose. NOTE: the SPAL fans do not have a heat shroud, and if
they touch a hot turbo, they'll probably melt.
Old Apr 10, 2002 | 10:54 PM
01geeser's Avatar
New User
Default Re: **WHAT FAN WILL FIT LS TURBO REX??** (echo999)
yeah i agree we need fan spec sheet.
AirWaveGT
Dec 1, 2004 03:32 PM
austrian type-R
Mar 12, 2003 04:31 PM
E-Rok
Nov 1, 2002 01:29 PM
.Ryan
Jun 6, 2002 09:16 AM
EF8SIR
Apr 10, 2002 01:46 PM
