Rolling noise - How can you tell whether it's the tire or the wheel bearing? (help)
Old May 10, 2006 | 07:13 AM
frostcivic's Avatar
Default Rolling noise - How can you tell whether it's the tire or the wheel bearing? (help)
Old May 10, 2006 | 07:17 AM
IHateJDM's Avatar
Default Re: Rolling noise - How can you tell whether it's the tire or the wheel bearing? (frostcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by frostcivic &raquo;</TD></TR><TR><TD CLASS="quote">???
Is one side louder than the other? that would probably mean wheel bearing. Jack up the car and shake the suspect wheel from side to side and see if the bearing is fucked.
Paxil4x4's Avatar
if its a wheel bearing it will go away when you turn
Old May 10, 2006 | 07:25 AM
EG2Driver's Avatar
Default Re: Rolling noise - How can you tell whether it's the tire or the wheel bearing? (packthis)
if its a bearing its gonna sound like a prop plane. My bro's car sounds like one, and his bearing is shot.
Old May 10, 2006 | 07:46 AM
frostcivic's Avatar
Default Re: Rolling noise - How can you tell whether it's the tire or the wheel bearing? (IHateJDM)
Yes, one side it louder than the other.
I have to check again if the sound dissappears when I turn.
Old May 10, 2006 | 07:55 AM
cranny's Avatar
24.224.233.247
the sound will disapear from the wheel thats makin it when you take the load off it. so if your left wheel bearing is bad , when you turn left it will quiet or go away. if its not a wheel bearing or doesnt disapear than it could be a trans bearing , one of the differential bearings maybe , axle.
Old May 10, 2006 | 08:35 AM
Syndacate's Avatar
seems to disappear when u turn u say?
Def. sounds like the wheel bearing, had the problem in 2 diff cars O.o
Old May 10, 2006 | 08:42 AM
ralphie14's Avatar
Default Re: (Syndacate)
Easiest way period. Jack up the front of your car so the wheel is not touching the ground. Grab the rim if you can physically wiggle the rim with the lugs tight then it is probably your wheel bearing. That is the way that I figured the problem out on my car.
Old May 10, 2006 | 09:18 AM
frostcivic's Avatar
Default Re: (ralphie14)
Thanks I'm going to try that out.
Old May 11, 2006 | 02:23 AM
Syndacate's Avatar
yeah, that's a good way to check it for sure..
Phil_46
Jun 11, 2013 09:16 PM
titosek4
Suspension & Brakes
Sep 29, 2011 05:02 PM
Mr_Moos
Jul 10, 2006 02:50 PM
Nice_Dc2r
Aug 21, 2003 01:11 PM
bus stop
19
Apr 22, 2003 12:18 AM
