where is this vac line going from the GM 3bar map?
Old May 10, 2006 | 06:22 AM
RTW DC2R's Avatar
Default where is this vac line going from the GM 3bar map?
In this pic, is the vacuum line coming off the GM 3bar going to the IM plenum? the stock map is on the other side of the TB, does it matter if you set up the 3bar on the IM side of the TB?
Old May 10, 2006 | 07:18 AM
drumking15's Avatar
its going to a port on the underside of the manifold....and no it doesnt matter where it goes on the mani...as long as its post throttlebody youll be fine
Old May 10, 2006 | 09:10 AM
boosted94cx's Avatar
* B A N N E D *
teh stock map reads from the plenum....the throttle body has a groove in it that goes to the plenum
Old May 10, 2006 | 09:46 AM
RTW DC2R's Avatar
thanks for clearing that up
Old May 10, 2006 | 10:31 AM
cuin9sec
Guest
Posts: n/a
Default Re: (drumking15)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drumking15 &raquo;</TD></TR><TR><TD CLASS="quote">as long as its post throttlebody youll be fine</TD></TR></TABLE>
Fuzzy Rhubarb
Oct 11, 2007 01:01 PM
90b20vteckidd
17
Sep 27, 2006 06:03 PM
PearlBlueType-S
Jan 21, 2006 10:35 PM
97grnrs
Dec 31, 2005 05:50 PM
