how hard is it
Old May 9, 2006 | 10:52 PM
luigi69's Avatar
Default how hard is it
how hard is it to just put in a new engine wiring harness in a 1991 honda civic ef is it easier to just modify the the old harness let me know asap thanks\
Old May 9, 2006 | 10:56 PM
crxnj's Avatar
Default Re: how hard is it (luigi69)
what exactly are you trying to do?
Old May 9, 2006 | 10:59 PM
luigi69's Avatar
Default Re: how hard is it (Mr.speaker)
im trying to do ls swap but i dont know if it would just be easir to just throw in an ls wiring harness or just modify my dual point fuel injection wiring harness
Old May 9, 2006 | 11:01 PM
24TEN's Avatar
PHANTOM MENACE
if i'm not mistaken, if you are swapping in an OBD0 B18A, other than the multi-point conversion, everything else should plug together. anyone, please correct me if i'm wrong.
Old May 9, 2006 | 11:04 PM
crxnj's Avatar
Default Re: (24TEN)
its alot easier to modify the stock harness then trying to get the integra one in there....all you have to do to the stock harness is add and switch around a couple wires..not really hard if you have some direction,,have you seen this how-to yet? http://crf50.no-ip.com/fourthgenhatch/mpfi.html if converting to obd1 also then theres other stuff you gotta do..
Old May 9, 2006 | 11:13 PM
luigi69's Avatar
Default Re: (Mr.speaker)
what kind of ecu do i need to run on obdo and what year ls motor am i suppost to use or does the motor not matter what year
Old May 9, 2006 | 11:16 PM
crxnj's Avatar
Default Re: (luigi69)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by luigi69 &raquo;</TD></TR><TR><TD CLASS="quote">what kind of ecu do i need to run on obdo and what year ls motor am i suppost to use or does the motor not matter what year</TD></TR></TABLE>
you use a 90-91 integra pr4 ecu to run obd0..for the year of the engine it would make things easier if it was a 90-91 ,,but if 92+ you can always convert it to obd0
Old May 9, 2006 | 11:18 PM
luigi69's Avatar
how do i convert a 92+ motor to obd0
Old May 9, 2006 | 11:21 PM
crxnj's Avatar
get a 90-91 b18a distributor..and the fuel injectors on the obd1 motors are saturated so you wont have to use a resistor box for the injectors
Old May 9, 2006 | 11:26 PM
luigi69's Avatar
thanks
hope fully this helps
Modified by luigi69 at 12:45 AM 5/10/2006
1BADEF
Sep 12, 2008 01:49 AM
90DAlsv
Dec 17, 2007 12:58 PM
bigluelok
Jun 25, 2007 12:12 PM
Chester Rumble
Feb 12, 2007 09:23 PM
apron8
Aug 14, 2003 03:21 PM
