help wierd results from swap
Old May 9, 2006 | 09:13 PM
skylude23's Avatar
Default help wierd results from swap
i just swaped my motor for a replacment h23 and when i tap the gas it sounds like its choking but when i keep that gas pressed it sounds fine and when i let go it sounds fine
but there is a lag or choking like when i drive 40mph and put it in fifth is sounds like im taking in water from my intake but the sun is out and theres no water anywhere Dry.
can it be my vacume lines or a snesor gone bad or something not pluged in right i do have a check light on?
Old May 10, 2006 | 06:08 AM
Suck my DX's Avatar
Default Re: help wierd results from swap (skylude22)
seems like u figured out your own problem at the end of ur post...find out why its throwing a code and fix it
Old May 12, 2006 | 06:16 PM
skylude23's Avatar
ok i changed my vacume tank and the check lite is still on and when i tap the gas it sounds like it wants to cut off but it still revs what could this be
Old May 13, 2006 | 10:38 PM
skylude23's Avatar
what hoses connect to the top of the transmittion and is it bad to run my car with those hoses unconnected
Old May 14, 2006 | 11:19 AM
Combustion Contraption's Avatar
Pull the goddamn code.
Old May 14, 2006 | 12:19 PM
mar778c's Avatar
Community Builder
Community Influencer
goto autozone or advance and get the code.
Old May 14, 2006 | 09:04 PM
skylude23's Avatar
Default Re: help wierd results from swap (mar778c)
ok ill try that thanx
Old May 18, 2006 | 01:47 AM
thahuhstunna's Avatar
let the OnBoard Diagnostic do its job
helpmygsr
Sep 14, 2012 10:25 AM
blacktibby07
Mar 8, 2011 08:01 AM
jordan2305
Jul 18, 2007 08:45 PM
99CivicExCoupe
Nov 19, 2004 10:25 PM
bigedx
Feb 6, 2004 01:50 PM
