oil pan and valve cover gasket leakage..
Old May 9, 2006 | 08:00 PM
94hatchvx's Avatar
Default oil pan and valve cover gasket leakage..
ok. i swapped a b16 sir2 into my 92 cx hb. well i noticed yesterday that there was oil runing down the block (when your looking under the hood) to the right of the header down that corner and out of that corner on the oil pan. So i replaced the oil pan gasket and torqued the bolts to spec and replaced the valve cover gasket and torqued those to spec. well i was driving around the next day and i happen to open my hood to show some one my swap and it is STILL LEAKING in the same spots! i dont know wuts wrong. anyone had this problem or know how to fix it?
Old May 10, 2006 | 12:40 PM
94hatchvx's Avatar
Default Re: oil pan and valve cover gasket leakage.. (94hatchvx)
anybody? i need help? they wont stop leaking.
Old May 10, 2006 | 12:42 PM
delacampos's Avatar
did you use any kind of sealant on the oil pan gasket?
new_climber
Aug 4, 2013 09:06 PM
walrus_07
Mar 7, 2009 01:21 PM
thudreem
Oct 20, 2006 08:43 AM
ITR-00-1457
Apr 11, 2005 06:26 PM
srburk
Dec 27, 2004 04:08 PM
