NJ AREA-GSR HARNESS-ECUs TYPE R-SOHC-CIVIC PLASTICS-BSERIES AC COMP-POWERSTERIN PUMP-VAFC AND MORE
Old May 9, 2006 | 06:53 PM
bak's Avatar
bak
Default NJ AREA-GSR HARNESS-ECUs TYPE R-SOHC-CIVIC PLASTICS-BSERIES AC COMP-POWERSTERIN PUMP-VAFC AND MORE
gsr throttle cable brand new-25$$$
**OBD2GSR WIRING HARNESS w/RC550 INJECTOR CLIPS-150$includes 2extra cut gsr harnesses.........
VAFC I-200$ with mount and instructions
REV SPEED METER II-150$ THE NEW VERSION
p73AO2 TYPE R ECU-200$
p06 sohc ecu-bo$$
96-98 CIVIC CLIMATE CONTROL PANEL NOT WITH SURROUND PANEL JUST THE SWITCH PART- MAKE OFF
BSERIES AC-COMPRESSOR-60$
BSERIES SPEED SENSOR-50$
CIVIC AC RADIOTAR WITH LINES-50$
ROTA SLIPSTREAM CENTER CAPS CARBON FIBER-40$
PREDULE STOCK SHIFTER ****-20$
JDM CENTER CONSOLE GOES OVER EBRAKE WITH OUT ARMREST THE OFFICAL JDM ONE BLACK-50$
96-98 COUPE REAR PLASTICS-40$
96-98 CIVIC KIK PANEL PLASTICs-20$
96-98 CIVIC COUPE BRAND NEW DOOR PANELS MANUAL-80$
obd2-obd1 CONVERTER HARNESS-80$
96-98 civic radio converter harness-10$
96-98 civic coupe dual gauge pod with AUTOMETER OIL PRESSURE GAUGE AND AIR/FUEL GAUGE-60$
SOHC SHIFTER LINKAGE-50$
miscelanous civic 96-98 parts plastics under stering wheel, defroster button, emergency lights button..make offers low prices
shifter consoles 2of them for 96-98 civic coupe grey colors-20$ each
92-95 eg center console with out armrest gray-40$
bseries powerstering pulley with pump-40$
99 SI FRONT BUMPER CHAMPionship WHITE-40$
908-623-6100alex
or aim snoopac69
Old Jun 23, 2006 | 02:12 AM
Paul's EK's Avatar
Default Re: NJ AREA-GSR HARNESS-ECUs TYPE R-SOHC-CIVIC PLASTICS-BSERIES AC COMP-POWERSTERIN PUMP-VAFC AND MO
miscelanous civic 96-98 parts plastics under stering wheel, defroster button, emergency lights button..make offers low prices <---have any off this left? Looking for the lower driver side dash plastic. (were the fuses are) in the dark grey
