higher speed power loss
Old May 9, 2006 | 05:44 PM
nonvteclude's Avatar
Default higher speed power loss?
ok so last weekend i was at a drag strip and noticed something. i have a few ideas of what it could be but not exactly sure.
the problem is, i have lots of power throught first and second. but when i hit third seems to be too drastic of a decrease for just shifting to 3rd.
my idea was i have too much air coming in and not enough out. or do i not have enough fuel going in. as for that i have an aem cold air, a bdl 70 mil throttle body, a streetperformaance and electronics helix tb spacer and a port and polish.
as for the out side i have the port and polish, dc sport headers. high flow cat. 2 1/4 piping with a brulen muffler.
so could it be just that i have too much air coming in and not enough out, or something else
Modified by nonvtechlude at 4:13 PM 5/10/2006
Old May 11, 2006 | 12:28 PM
Default Re: higher speed power loss? (nonvtechlude)
any one have any ideas on this
Old May 11, 2006 | 01:00 PM
Chuckles99SH's Avatar
your dc header is probably choking your car of power, get a SMSP or RMF or other quality header and you will see gains. Have you tuned your car?
Old May 11, 2006 | 01:30 PM
cgo_62's Avatar
just an idea...
if you had concerns about too much/little air and fuel, then your car should be affected at all gears. you stated that 1st and 2nd were fine; Why would third be different?
in other words, if you had bad air:fuel ratios, your rpm's will determine the "error" domain and not what gear you're in. my idea is that third has longer gearing and longer gears affect how much torque is put to the ground.
https://honda-tech.com/zerothread/1593351
Old May 11, 2006 | 03:03 PM
Mervin's Avatar
Default Re: higher speed power loss? (cgo_62)
Ive noticed the same since I changed the fly to a 9lbs piece and bolted on a complete set of UR underdrive pulleys
I think the engine lost too much of the rotational inertia, which could translate to less torque.....correct me if im wrong though........
First and second are badass though and revs pick up like an offroad two stroke hehehe
Old May 12, 2006 | 08:58 PM
(((((just an idea...
in other words, if you had bad air:fuel ratios, your rpm's will determine the "error" domain and not what gear you're in. my idea is that third has longer gearing and longer gears affect how much torque is put to the ground.)))))
the reason i had this concern was cuase when in third car seemed to choke alittle, cuasing me to think that the back pressure has to high or something, and for the fuel i hadnt been able to dyno tune the afc for the new climate, i had it tuned in alb new mexico and now live in denver. but thanks for the ideas
Old May 13, 2006 | 05:36 AM
mgags7's Avatar
2.25" exhaust is small....
what motor is in your car?
Old May 13, 2006 | 08:10 AM
GaRn's Avatar
Default Re: (mgags7)
first of all, what was your time and your trap speed?
Old May 16, 2006 | 04:42 PM
Default Re: (GaRn)
its an h23, the 1/4 mile time was 13.7 @ 109
Old May 16, 2006 | 05:49 PM
gooseman's Avatar
Default Re: (nonvtechlude)
pretty fast for h23. my h22 has that same feeling, i just know it's 3rd gear i feel a drop in power too. i think 3rd is too long because honda's all about fuel mileage. but i don't......
Old May 16, 2006 | 06:47 PM
Default Re: (gooseman)
cool man thanks for you input, i guess will just have to do gears
tek_civic
Honda Motorcycles
Mar 12, 2014 12:32 PM
mortificationrock
15
Sep 15, 2009 08:31 PM
nelsond
Oct 5, 2005 03:12 PM
civic91
Jan 5, 2004 06:56 PM
abeaujuin
Jun 25, 2002 04:22 AM
