HELP with ingalls camber kit install
Old May 9, 2006 | 05:30 PM
88crx-si's Avatar
Default HELP with ingalls camber kit install
so i finally had time to install my camber kit i have had for a few months.
good thing i decided to do it today because i'm running into some problems.
did i put them in backwards? the camber kit hits the control arm.
i searched and found a few posts that say that when installed,
the rounded end should face outwards. is that right or no?
also, am i supposed to reuse the brace that holds them together?
thanks in advance
-matthew
Old May 9, 2006 | 05:49 PM
Crx Jimmy's Avatar
Default Re: HELP with ingalls camber kit install (88crx-si)
No, you dont need that brace anymore and you need to adjust them out farther so they dont hit, just loosen the bolt and pull out till it doesnt hit anymore it will be readjusted on the alignment rack
Old May 9, 2006 | 07:22 PM
8atman's Avatar
the only problem about the ingalls is that it pushes the uca out further into the wheel well which can be a bitch. i got the ingalls set up first found this out and got rid of them then got the spc upper ball joint set up which works great. Good luck with your project hopfully the ingalls work for you.
actek23
Suspension & Brakes
Oct 26, 2007 05:53 AM
highrevnef
May 18, 2005 07:50 AM
allmotorEG-SI
Jul 18, 2004 11:33 AM
xvracing
Aug 27, 2003 06:42 PM
TexTeg
Jan 21, 2002 09:25 AM
