D15B1 head question
Old May 9, 2006 | 03:05 PM
Almost There's Avatar
Default D15B1 head question
i was just wondering about a D15B1 head and would a D16A6 distributor work on it?
Old May 9, 2006 | 06:47 PM
i didnt know if the D15 is obd0 and it used the same distributor as the A6
Old May 10, 2006 | 10:23 AM
bump
Old May 10, 2006 | 10:40 AM
Civiclized's Avatar
Default Re: (Almost There)
I have researched fully.I work in an auto parts store and just finished dhecking my catalogs. It may be a possibility that the number on a certain distributor may work.
But all I can tell you is that a 1990 D15b1 uses a part #TD-18U OR A TD-01U.
A 1990 D16A6 uses a part #TD-01U OR A TD-18U.
So according to the factory numbers it would seem that they shoukd interchange, but that was also just a wild guess in a 90 model.
Just my two cents
Old May 10, 2006 | 10:51 AM
tyro's Avatar
Default Re: (Civiclized)
It will fit mechanically.
I'm pretty sure the A6 has a cylinder position sensor in the dizzy while the B1 does not.
Hope this helps
Old May 21, 2006 | 06:59 PM
tegmaniac's Avatar
Default Re: (tyro)
I know the connector is different
Nov 7, 2015 01:01 PM
E-Money
Nov 4, 2010 12:19 PM
goforbroke
11
Aug 30, 2005 02:30 PM
blackdc
Nov 2, 2004 05:35 PM
Donkey85
Jun 2, 2003 08:40 PM
