!!!!OEM HONDA PARTS AT A DISCOUNT!!!!
Need these parts... prices I got from other online websites.
Honda:
Part Part # Price
BROWSE > CIVIC > 2000 > 2DR SI > 5MTKA > ENGINE > CAMSHAFT-TIMING BELT (2)
SPRING, TIMING BELT ADJUSTING 14516-P2T-000 $3.27
OIL SEAL (29X43X8) (ARAI) 91213-PR3-004 $4.62
BROWSE > CIVIC > 2000 > 2DR SI > 5MTKA > ENGINE > CYLINDER BLOCK-OIL PAN (2)
OIL SEAL (80X100X10) (ARAI) 91214-PH1-004 $11.95
GASKET, OIL PAN 11251-P30-004 $20.21
BROWSE > CIVIC > 2000 > 2DR SI > 5MTKA > ENGINE > CYLINDER HEAD (3)
FILTER ASSY., SPOOL VALVE 15825-P08-005 $12.68
BROWSE > CIVIC > 2000 > 2DR SI > 5MTKA > ENGINE > CYLINDER HEAD COVER
GASKET SET, HEAD COVER 12030-P30-000 $34.91
BROWSE > CIVIC > 2000 > 2DR SI > 5MTKA > ENGINE > DISTRIBUTOR (TEC-WEASTEC)
O-RING (26.4X3.1) (TEC) 30110-PA1-732 $1.35
BROWSE > CIVIC > 2000 > 2DR SI > 5MTKA > ENGINE > GASKET KIT
GASKET KIT, CYLINDER BLOCK 06111-P2T-000 $45.39
BROWSE > CIVIC > 2000 > 2DR SI > 5MTKA > ENGINE > OIL PUMP-OIL STRAINER (2)
PUMP ASSY., OIL 15100-P72-A01 $95.57
BROWSE > CIVIC > 2000 > 2DR SI > 5MTKA > ENGINE > THROTTLE BODY (4)
GASKET, ELECTRONIC AIR CONTROLVALVE 36455-PT3-A01 $1.77
BROWSE > CIVIC > 2000 > 2DR SI > 5MTKA > ENGINE > WATER PUMP-THERMOSTAT (2)
THERMOSTAT ASSY. (NIPPON THERMOSTAT) 19301-P08-316 $12.68
Honda:
Part Part # Price
need itr front (both sides) hub, bearing and circlip with wheel bolts (10 in total)
plus rear hub and bearing assembly with wheel bolts (10 in total)
lemme know how much it comes to.
Guest
Posts: n/a
for all the pm's about itr/gsr/acura parts i can get them but i need for you to get the part #'s from acura dealership and then i can order it for cheap. we cannot look up acura parts in our system but can get them with the part #'s
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by john d »</TD></TR><TR><TD CLASS="quote">for all the pm's about itr/gsr/acura parts i can get them but i need for you to get the part #'s from acura dealership and then i can order it for cheap. we cannot look up acura parts in our system but can get them with the part #'s</TD></TR></TABLE>
cool, guess ill be making a few calls myself or go online to find part #s.
Guest
Posts: n/a
got some prices today and made shipped out a few items already
if you need acura parts please call up your local dealership and get the part # like this guy...........
88 Crx Si (12:48 AM 5/10/2006): 13011-PR3-003.....13021-PR3-003 it was showing two so i don't know which # is the right one...piston rings
11810-PR3-010 gsr timing belt,12251-PR4-004 LS Head gasket.....lmk how much
PLEASE ALSO LIST WHAT U WANTED ITS HARD TO KEEP TRACK!!
I need front fender lining/splash guard for both sides for a 2000 Honda Civic coupe. Also need the clips that holds them.
Any gray/dark gray Authentic Honda civic 2dr floor mats.
Thanks. LMK
Also need brake pads for a 2000 Accord LX V6 coupe.
Thanks. LMK
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egredspools »</TD></TR><TR><TD CLASS="quote">If ur in the MD/DC/VA/PA/DA let me know if u want honda at wholesale work at benz/aston martin parts so holla and ill hook u up???
</TD></TR></TABLE>im in tx
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blkcivicpn0i »</TD></TR><TR><TD CLASS="quote">I need front fender lining/splash guard for both sides for a 2000 Honda Civic coupe. Also need the clips that holds them.
Thanks. LMK </TD></TR></TABLE>
ill check on the dark gray floor mats, the splash guard would be gay to ship
im in tx
ill check on the dark gray floor mats, the splash guard would be gay to ship</TD></TR></TABLE>
YEAH I WAS SAYING IF UR IN MY HOOD ILL HOOK EM UP.....
im in tx
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek9vboi2 »</TD></TR><TR><TD CLASS="quote">Need these parts... prices I got from other online websites.
Honda:
Part Part # Price
THERMOSTAT ASSY. (NIPPON THERMOSTAT) 19301-P08-316 $12.68</TD></TR></TABLE>
Honda:
Part Part # Price
pm'ing you
