((NEED HELP!!)) d16 Bottom end fit on Zc head?
Old May 9, 2006 | 01:52 PM
HybridB18Vtec's Avatar
Default ((NEED HELP!!)) d16 Bottom end fit on Zc head?
I need help I Got a d16 bottom END and a ZC head. My Question is if the ZC head will fit on the d16 Bottom end ?! please let me know ASAP!
Old May 9, 2006 | 02:21 PM
EP3_05's Avatar
Default Re: ((NEED HELP!!)) d16 Bottom end fit on Zc head? (HybridB18Vtec)
The DOHC ZC head will not fit but the SOHC ZC head will bolt to the d16 bottom end.
SIred91's Avatar
Rainman
without asking about sohc vs. dohc your answer is yes.
within reason a D series is a D series
and ZC is a D series.
Old May 9, 2006 | 02:23 PM
DEIVIONCRX's Avatar
Default Re: ((NEED HELP!!)) d16 Bottom end fit on Zc head? (SIred91)
i think it will fit, but i think something might need to be dremel'ed or changed
Old May 9, 2006 | 02:34 PM
crxnj's Avatar
is the d16 bottom a sohc or a dohc and is zc head sohc or dohc?..if both are sohc ,it will fit
Old May 9, 2006 | 02:50 PM
SIRX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIred91 &raquo;</TD></TR><TR><TD CLASS="quote">without asking about sohc vs. dohc your answer is yes.
and ZC is a D series.</TD></TR></TABLE>
STFU noob. a DOHC ZC head will not fit a sohc D series block
Old May 9, 2006 | 04:35 PM
SIred91's Avatar
Rainman
Default Re: ((NEED HELP!!)) d16 Bottom end fit on Zc head? (SIRX)
no ****, i covered that you idiot.
dohc to dohc
sohc to sohc
i bet your one of the idiots who doesnt know a zc is sohc also.
Old May 9, 2006 | 05:00 PM
LShatchie's Avatar
you can put the dohc zc head on a sohc block, just takes minor machining to do so... someone here on honda-tech did it, but imo its not worth it
Old May 10, 2006 | 12:50 AM
THANKS ALOT GUYS!!!
Sorry i forgot too put That the bottom end was a SOHC D16 and Top ZC is DOHC.
But u guys answered my question.
ONCE AGAIN THANK YOU VERY MUCH!!!
P.s.
I luv u guys....
Old May 10, 2006 | 08:03 AM
SIred91's Avatar
Rainman
ahhh, we love you too.
Old May 10, 2006 | 10:25 AM
CRvtecHB91's Avatar
yes a single cam will but the dohc will not and withe zc sohc bein vtec yoy will need some wiring done to wire up the vtec and i think you will need a oil line kit for the vtec because a non vtec block has different oil ports and thus vtec is valve timing w/electronic control it needs more oil to the head to make up for the extra work vtec does get it i will learn youu
Old May 10, 2006 | 10:32 AM
CRvtecHB91's Avatar
dude get to know what ur talking bout b4 u just tell someone some stuff u dont know about there are three differant kinds of zc's and one of them was vtec and it was single cam then there is a dohc non vtec see they are all considered d series but a dohc wont bolt to a sohc block so maybe u just wanted to be a douch or u wer tired or sumfin but if u knew that just take a couple of min's to explain urself b4 u get all profesionalized on us thnx
Old May 10, 2006 | 11:09 AM
SIred91's Avatar
Rainman
Default Re: ((NEED HELP!!)) d16 Bottom end fit on Zc head? (CRvtecHB91)
i hope you arent telling me i dont know about zc.
i have a sohc NO VTEC
i have a dohc NO VTEC
and the zc comes vtec in both forms. its just the jap D series.
Why dont you do YOUR homework before telling someone they dont know what they are talking about.
Go to TheZCrecource.com
IS THIS PLAIN ENOUGH FOR YOU?
SOHC =SOHC
DOHC=DOHC END OF STORY SCHOOLBOY.
Old May 10, 2006 | 11:17 AM
jdm91CrxSi's Avatar
There Is a Red Button Uppon the Right Hand Side Of Your Screen call SEARCH!!!
Old May 10, 2006 | 12:12 PM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIred91 &raquo;</TD></TR><TR><TD CLASS="quote">i hope you arent telling me i dont know about zc.
Um, there is no DOHC VTEC ZC.
Old May 10, 2006 | 01:49 PM
SIRX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIred91 &raquo;</TD></TR><TR><TD CLASS="quote">no ****, i covered that you idiot.
dohc to dohc
sohc to sohc
i bet your one of the idiots who doesnt know a zc is sohc also.</TD></TR></TABLE>
you didn't cover it in your first post you tool. The second post you did bring it up. In the first post you didn't say much at all. And I know the differences between all the ZC's thank you...
Old May 10, 2006 | 02:13 PM
jlicrx's Avatar
Default Re: ((NEED HELP!!)) d16 Bottom end fit on Zc head? (LShatchie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LShatchie &raquo;</TD></TR><TR><TD CLASS="quote">you can put the dohc zc head on a sohc block, just takes minor machining to do so</TD></TR></TABLE>
takes a little more than what most people would consider minor machining, but it can be done
DOHC ZC head on D16Y7 block
Old May 10, 2006 | 02:21 PM
Targa250R's Avatar
be professional
Default Re: ((NEED HELP!!)) d16 Bottom end fit on Zc head? (jlicrx)
Looks like a 1st-gen/brown-top DOHC ZC head, specifically.
Old May 10, 2006 | 02:49 PM
jlicrx's Avatar
Default Re: ((NEED HELP!!)) d16 Bottom end fit on Zc head? (Targa250R)
looks to me like a DOHC ZC head with D16A1 valve cover - head does have tabs for the ZC valve cover
Old May 10, 2006 | 03:13 PM
SIred91's Avatar
Rainman
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R &raquo;</TD></TR><TR><TD CLASS="quote">
Um, there is no DOHC VTEC ZC.</TD></TR></TABLE>
hmmmm, look at all models of ballade and integra in japan and i think you will be pleasently surprised.
Old May 10, 2006 | 03:28 PM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIred91 &raquo;</TD></TR><TR><TD CLASS="quote">hmmmm, look at all models of ballade and integra in japan and i think you will be pleasently surprised.</TD></TR></TABLE>
Okay.
Find me a picture of a DOHC VTEC engine with a "ZC" block stamp.
Old May 10, 2006 | 05:11 PM
dawson_05's Avatar
no such thing as a dohc vtec zc and from what ive heard matching a dohc head with a sohc block they **** oil and coolent out but that pic might have proved me wrong
duefuss
Jan 24, 2008 09:12 PM
rice a roni
Apr 13, 2006 04:59 PM
bazookatooth
Feb 10, 2005 12:20 AM
boosted_zc
Apr 6, 2003 09:36 AM
Hybrid
12
Mar 11, 2002 07:35 PM
