Suspension Question?
Old May 9, 2006 | 12:12 PM
Boosted_Rex.'s Avatar
Default Suspension Question?
Im planning on ordering a St Rear Sway,Front lca poly bushings. Now should i order both sways or just the rear? does the front make a diff? let me know kthnx
Old May 9, 2006 | 12:32 PM
Tyson's Avatar
Default Re: Suspension Question? (Jspek_Rex)
just the rear and forget the poly bushings.
the front swaybar is too big for any good. and there are cheaper oem options for a stiffer front bar that arent so extreme either if you needed to stiffen the front. most ppl dont bother.
Old May 9, 2006 | 01:06 PM
Default Re: Suspension Question? (Tyson)
So what would you reccomend Rear Sway? OEM Front is good?
Old May 9, 2006 | 02:26 PM
Tyson's Avatar
suspension techniques is fine for the rear.
oem front is fine. some go even less stiff with an HF front bar. its hollow and thinner. i personally use a 4dr sedan front bar, which is bigger by 1mm. also the DA integra front bar fits, its 23mm but hollow. its pretty equivalent to the 19mm 4dr sedan bar.
Old May 10, 2006 | 04:04 PM
soichiro88's Avatar
suspesion question
Old May 10, 2006 | 04:14 PM
soichiro88's Avatar
Default Re: (soichiro88)
can you help me with a suspesion question?
Old May 10, 2006 | 04:15 PM
Steri's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by soichiro88 &raquo;</TD></TR><TR><TD CLASS="quote">suspesion question</TD></TR></TABLE>
LOL what???
Old May 10, 2006 | 04:16 PM
Steri's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by soichiro88 &raquo;</TD></TR><TR><TD CLASS="quote">can you help me with a suspesion question?</TD></TR></TABLE>
Make a new topic about it.
say bye to my B18
Suspension & Brakes
Apr 2, 2008 07:10 PM
AamirCWITR
May 12, 2007 04:06 PM
usdm97DC4
Suspension & Brakes
15
Mar 31, 2006 06:06 PM
oneslodx
13
Aug 20, 2004 01:07 PM
