Who sells synchronizers other then Gear-Speed.com
Old May 9, 2006 | 12:08 PM
Ntense90crxsi's Avatar
Default Who sells synchronizers other then Gear-Speed.com
I cannot seem to find anyone that carries synchros whatsoever, ecspecially carbon coated ones. I have been waiting on Gear-Speed for like 4 months on their backorder for B series cable tranny's. I have a Y1 and need synchros like yesterday 4 years ago. Could someone please point me in the right direction. Even if it is for some stockies, better then bad ones.
Old May 9, 2006 | 12:37 PM
SL0WEGG's Avatar
Default Re: Who sells synchronizers other then Gear-Speed.com (Ntense90crxsi)
why not call honda?
Old May 9, 2006 | 06:01 PM
Default Re: Who sells synchronizers other then Gear-Speed.com (boostedej1)
they want to sell me the whole sleeve set, not just the synchros
Old May 10, 2006 | 02:49 PM
non-VTEC's Avatar
i orderd some gear-speed carbon coated syncro's from this guy: https://honda-tech.com/zerothread?id=1085206
but he's a distributor for gear-speed. BUT if gear-speed has the ones you need on back order then chances are he wont be able to get them for you either.
but its worth a shot i suppose.......PM him and find out.
Old May 10, 2006 | 05:12 PM
Jim Truett's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ntense90crxsi &raquo;</TD></TR><TR><TD CLASS="quote">they want to sell me the whole sleeve set, not just the synchros</TD></TR></TABLE>
What do the dog teeth look like on the synchro sleeve and the corresponding gear? If they have been grinding they are most likely in need of replacement too.
Old May 10, 2006 | 07:00 PM
Default Re: Who sells synchronizers other then Gear-Speed.com (Jim Truett)
haven't tore it down yet but it almost won't shift into 4th.
Old May 10, 2006 | 08:00 PM
Jim Truett's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ntense90crxsi &raquo;</TD></TR><TR><TD CLASS="quote">haven't tore it down yet but it almost won't shift into 4th.</TD></TR></TABLE>
Inspect the sleeve and gear before you replace just the synchros. Before reassembly you can also remove the shine from the cone on the gears with 600 grit sandpaper for extra initial bite.
Old May 11, 2006 | 06:19 AM
thanks for the tips, every little bit helps down the 1/4m.
Old May 11, 2006 | 04:01 PM
BigMoose's Avatar
Dave has tranny rebuild kits including synchro's here http://sms-products.com/TrannyKits.html drop him an email, perhaps he can get the carbon coated synchro's for you.
dc2turbo
Feb 6, 2007 02:21 PM
teri_vti
14
Jan 21, 2007 02:26 AM
Kingsta18
Honda S2000
10
Jul 14, 2006 05:03 AM
jisu009
Apr 25, 2006 09:44 AM
crix868
Apr 17, 2005 12:47 AM
