Legend caliper Swap Worthwhile?
I know some people have done the swap and were pleased. All in all do you think the swap is worthwhile? Also aside from Vtec sized Rotors and legend pads (need new ones anyway), what else I am going to need? Just the Legend calipers and the shim for the brake pads? Also how much do the legen calipers run, and which ones do I need? And for that matter how much are all the parts to rebuild the legend calipers?
Next ist he actual install. How hard is it? Aside from the shim is it the exact same procedure/dificulty of replacing regulard prelude rotors/pads/calipers? How long should the whole install take (just to put them on the car, not the actual caliper rebuildling and what not).
Last concern is the brake lines. If I run stock brake lines, will the prelude ones bolt up fine to the legends? Any concerns with the lines? Also if I change the brake lines latter on are the legend and prelude lines the same? Which ones will I want to use?
Thanks, and sorry for the many questions.
-Jordan
-Jordan
Check it out.. I know it's a long read, but it has all the info you want to know.
https://honda-tech.com/zerothread?id=134651
Chugger
Oct 7, 2001 07:36 AM
