Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Too much oversteer
Old May 9, 2006 | 10:58 AM
j spec's Avatar
Default Too much oversteer
just returned from my first autocross with my totally new setup; the old was an h22 in a eg hatch on crappy tires and no sway bars, new setup is same car with gsr engine, lsd, integra gsr front/rear sway bars skunk2 upper control arms, and gsr brakes and subframe with powersteering and new azenis rt 615's. first of all the new setup handles great understeering feels nearly non existent and car feels much more agile and controlable. but the rear has gained a good bit of oversteer, i was planning on adding a asr subframe reinforcement with the 23mm itr sway bar but to my understanding this will only increase the unwanted oversteer. just wandering anyone's opinon on the itr sway bar as well on the general issue and how others control their oversteer. thanks
Old May 9, 2006 | 11:09 AM
maxQ's Avatar
Default Re: Too much oversteer (roma's GSReg6)
More gas. Smoother inputs.
<--- hasn't met an oversteer he doesn't like.
Old May 9, 2006 | 11:12 AM
j spec's Avatar
Default Re: Too much oversteer (maxQ)
oversteer is the problem mainly in slaloms which i forgot to state to begin with.
Old May 9, 2006 | 11:20 AM
EJ1 wilcox's Avatar
You should be able to correct any oversteer you are experiencing with changing your driving a bit.
Your setup doesn't sound extreeme enough to produce uncontrollable oversteer.
Old May 9, 2006 | 11:29 AM
merritr's Avatar
Default Re: Too much oversteer (EJ1 wilcox)
Especially in a situation like autocrossing, you could really play with how the car oversteers just by adjusting your tire pressures.
Old May 9, 2006 | 11:44 AM
dvp's Avatar
dvp
Default Re: Too much oversteer (merritr)
It very well might be your inputs but you can have too much oversteer with this car.
If you have adjustable shocks, make the fronts a bit stiffer or the rears softer. Adding more bar in the rear will add more oversteer.
What are your alignment settings?
Old May 9, 2006 | 05:36 PM
smokin rubber's Avatar
stock springs and shocks and your getting oversteer? You must really be throwing it around.
Old May 9, 2006 | 05:43 PM
j spec's Avatar
Default Re: (smokin rubber)
the shocks are stock but i have coilovers on it. oh and the camber is approximately -1 degree front and rear
Old May 9, 2006 | 05:46 PM
slammed_93_hatch's Avatar
Default Re: (roma's GSReg6)
its the nut behind the wheel
the sooner you relize this the sooner you can get faster, or try to get faster in my case
Old May 9, 2006 | 06:26 PM
PIC Performance's Avatar
Did you have an alignment done after doing the suspension work?
Old May 9, 2006 | 08:31 PM
urbanlegend21's Avatar
New User
Default Re: Too much oversteer (PIC Performance)
You have more grip in the front end now and added a little more rotation to the rear, I agree with Karl though, oversteer on that setup would be terrifik
Old May 9, 2006 | 09:50 PM
CRX7's Avatar
I'm amazed you can get that setup to oversteer. I'd usually have to use the ebrake to get oversteer with the stock swaybar.
See the thing is.. you Want oversteer in a FWD car, cuz you hit the gas and it goes straight... see easy.
If you're having problems with oversteer in the slalom, keep your speed steady, get a good entrance speed you can handle and don't come on and off the gas so hard, nut.
Old May 10, 2006 | 10:22 AM
j spec's Avatar
Default Re: (CRX7)
i did get an allignment done after i installed all the stuff. well i guess my question is whether the larger itr sway bar will increase the issue or help control it. either way i will try to play with the tire pressure a little more and try setting the camber neg a little also. and what does everyone mean by inputs?
Old May 10, 2006 | 10:34 AM
you controls of the car, steering, brake, throttle. You need to be smooth to be fast.
Try and get a ride with a faster driver at the next event, or have one of them ride with you to give you instant feedback.
Old May 10, 2006 | 11:11 AM
Mugenlude's Avatar
inputs = you're application on throttle, brake, and steering.
A larger rear sway bar of the same design (hollow vs. solid) is going to induce MORE oversteer.
Could you give us some alignment specs, along with the tire pressure you are running? This could very well be a driver induced problem, but if you're setup is out of whack it isn't going to help...
Camber (F/R)
Toe (F/R)
Tire Pressures (F/R)
stock springs?
Old May 10, 2006 | 01:46 PM
RacerZook's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by roma’s GSReg6 &raquo;</TD></TR><TR><TD CLASS="quote">just returned from my first autocross with my totally new setup; the old was an h22 in a eg hatch on crappy tires and no sway bars, </TD></TR></TABLE>
That's the "problem". If you're used to driving/auto-xing a car with no swaybars, a car with swaybars is going to feel completely different. Plus without all that extra weight over the front end, it won't plow so much. You just need time and practice to get used to and comfortable with the new setup.
Plus with the LSD, it's really easy to control oversteer. rear end get a little loose? Just give it more gas. You can really change the attitude of the car by just using the gas pedal in a turn.
Old May 10, 2006 | 05:32 PM
MrTodd's Avatar
Default Re: (CRX7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX7 &raquo;</TD></TR><TR><TD CLASS="quote">I'm amazed you can get that setup to oversteer. I'd usually have to use the ebrake to get oversteer with the stock swaybar. </TD></TR></TABLE>
E-Brake???? Are you serious??? I've never touched the e-brake during auto-x and I can get a HELL of a lot of rotation/oversteer. And guess what? My suspension is COMPLETELY stock. No swaybars.
It's all about driver input, and adjusting tire pressures - as stated above.
Old May 10, 2006 | 06:32 PM
j spec's Avatar
Default Re: (MrTodd)
yeah i guess smoother inputs will solve most of the problem along with me getting used to the new setup i only had 9 runs and haven't been to a test and tune yet. Seems like everytime i try to get a little practice on the street or empty parking lot late at night i end up with a wreckless driving ticket from the local fuzz. oh and lsd does help tremendously when pulling out of the oversteer. also i played with tire pressure from 40 -45 psi front and rear, the front does great anywhere in that range on the rt 615's, and does anyone run lower pressure on there similar setups.
Old May 11, 2006 | 06:28 AM
Mugenlude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by roma’s GSReg6 &raquo;</TD></TR><TR><TD CLASS="quote">Seems like everytime i try to get a little practice on the street or empty parking lot late at night i end up with a wreckless driving ticket from the local fuzz. </TD></TR></TABLE>What do you expect... keep the racing where it belongs, at events.
As far as tire pressures, 40-45 psi for the front seems to be about right for the RT-615's.
Old May 11, 2006 | 09:31 AM
dvp's Avatar
dvp
Default Re: (Mugenlude)
Do we get an answer on your alignment settings?
Old May 11, 2006 | 09:46 AM
j spec's Avatar
Default Re: (dvp)
-1 degree front and rear. thanks
Old May 13, 2006 | 07:59 AM
95Bubble's Avatar
in auto x alignment is a big issue, be sure to be very smooth with your imputs, i know im repeating what everyone has said, ive been racing for 3 years, i took my stock 95 hatch with 175 section width tires with 6 year old good year t metrics tires and was only 8 seconds of the FTD!!! make sure your camber isnt too much in the rear!!!
Old May 14, 2006 | 12:46 AM
pos_cd5's Avatar
Default Re: (95Bubble)
bump the tire pressure up in the rear......and work on your driving, remember basic car dynamics...gas off/brake=weight transfer to front=unloading rear tires=overtseer!
Old May 14, 2006 | 03:44 AM
Type_RS_59's Avatar
Default Re: (pos_cd5)
slow down before the slalom and accelerate lightly through it. you will not get oversteer if you are on the gas ans dmooth with your steering inputs. it helps if you learn to left foot brake too. that way you can brake hard while keeping the car from nose driving and unloading the rear tires.
Old May 14, 2006 | 01:17 PM
j spec's Avatar
Default Re: (Type_RS_59)
left foot braking is definetely one thing i want to practice with and i think it should help alot. thanks
