Bad IACV...need quick fix
Old May 9, 2006 | 10:53 AM
ImprezaSTi01's Avatar
Default Bad IACV...need quick fix
Well...as far as i know my IACV is bad...it idles at 800...and then goes to 2000 and drops and then 2000 and drops...back and forth...i need a quick fix for this...and a cheap/free one too. I need to pass emissions in MA but they do an emissions idle test and it wont pass with this idle...or does someone have a good one they can send me? or can i clean it? or can i test a junkyard one while im in the yard so i know its good?
HELP PLEASE!
-Matt
Old May 9, 2006 | 11:08 AM
mcclungd2000's Avatar
Default Re: Bad IACV...need quick fix (ImprezaSTi01)
hey there,
i had the same problem on my 98 gsr. come to find out it wasn't the iacv at all. The guy i bought it from thought that the stop screw for the butterfly was the idle screw. after trying everything including swapping out iacv from junk yards, my mechanic told me to check out the stop screw and what do you know, that was the problem. have you tried cleaning it? take it off and spray out the screen with carb cleaner. make sure you dry it off completly before reinstalling. then reset ecu and see if that worked. i'm using one off a b16. the bolts lined up and the plug was the same. no problems after 6 months. good luck!
Old May 9, 2006 | 11:09 AM
JDMorgan's Avatar
you can unplug it and pull the check engine light bulb out. in ct they check ur cluster for check engine light.
Old May 9, 2006 | 11:15 AM
alright...ill take it off and clean it...and check all my idle screws and crap...i dont even know what it looks like but ill find it...im new to hondas...so used to my rx7 this is confusing...
PISTONS??? WHAT ARE THOSE??? haha...oh well...ill figure it out
Old May 9, 2006 | 11:30 AM
JDMorgan's Avatar
Default Re: (ImprezaSTi01)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ImprezaSTi01 &raquo;</TD></TR><TR><TD CLASS="quote">PISTONS??? WHAT ARE THOSE??? haha...oh well...ill figure it out</TD></TR></TABLE>
they go up and down.
KP_EG
Feb 13, 2015 10:37 PM
thewrai6th
Apr 29, 2014 12:59 PM
lev253
Oct 31, 2011 05:57 PM
BlueSmartEm1
15
May 16, 2011 06:32 AM
91dxhatch
Jan 4, 2007 11:46 AM
