Suspension & Brakes Theory, alignment, spring rates....
***Koni Yellow Liquid/Greasy Substance***
Old May 9, 2006 | 10:49 AM
ecahatch's Avatar
Senor Miembro
Default ***Koni Yellow Liquid/Greasy Substance***
thanks! plz delete.
Modified by ECAhatch at 10:09 AM 5/14/2006
Old May 9, 2006 | 10:59 AM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: ***Koni Yellow Liquid/Greasy Substance*** (ECAhatch)
I have heard of Koni's leaking from the top of the shock shaft where the adjuster is. A little moisture is normal, but drips & runs are not. Try to see if this IS where the oil is coming from. Hopefully CRX Lee will catch this thread & give you his professional opinion. If he doesn't respond in a few hours, shoot him a PM (he's our local H-T Koni rep)...
Old May 9, 2006 | 11:07 AM
ecahatch's Avatar
Senor Miembro
Default Re: ***Koni Yellow Liquid/Greasy Substance*** (94eg!)
thanks for that info!
i wiped it down totally....i will check tomorrow after driving if that stuff shows up again.
Old May 9, 2006 | 11:29 AM
Chase's Avatar
greasy!
did i mention that i want the girl in ur avatar?
Good luck homes
Old May 9, 2006 | 11:37 AM
Marauder's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ECAhatch &raquo;</TD></TR><TR><TD CLASS="quote">
Isn't that cup washer supposed to be flipped the other way around?
Be like... \__/
Old May 9, 2006 | 11:40 AM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: ***Koni Yellow Liquid/Greasy Substance*** (Marauder)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Marauder &raquo;</TD></TR><TR><TD CLASS="quote">Isn't that cup washer supposed to be flipped the other way around?
Be like... \__/</TD></TR></TABLE>
WOW! That's a pretty good eye. He's absoloutly correct. You have the washers on upside down. With them like that, the edges of the washer will destroy the bushing. It's a pretty common mistake...
Old May 9, 2006 | 01:57 PM
ecahatch's Avatar
Senor Miembro
gahhhhhhh! never knew. bought em new from a guy that just assembled it. thanks!
Old May 9, 2006 | 02:14 PM
ecahatch's Avatar
Senor Miembro
just fixed em.... good news.....bushings aren't ripped or damaged. Thanks again!
Old May 9, 2006 | 06:18 PM
stumpyf4's Avatar
If the shocks are leaking the oil should go down... not up to the top mounts. Take off the wheels and check the shock bodies for oil residue. You're probably not running dust seals/boots so it should be easy to see of the shaft seal is leaking.
Old May 9, 2006 | 06:38 PM
CRX Lee's Avatar
Default Re: ***Koni Yellow Liquid/Greasy Substance*** (stumpyf4)
Wipe the oil down at the top and check the rate at which the oil is returning but I do think it is likely that the O-ruing under the adjuster tab is leaking a bit if it returns. Although I can't see volume, that does look like shock oil.
I noticed the cup washer being upside down as well and that can casue bushing bind and premature wear out of the bushing but the others beat me to it.
Wipe 'em down and check the rate of return. If it comes back pretty quickly, contact Bob or Stoney in Koni Tech at 859-586-4100 option 6 and it would be good to have a copy of your purchase receipt and registration available to get the ball rolling.
Old May 10, 2006 | 04:40 AM
ecahatch's Avatar
Senor Miembro
Default Re: ***Koni Yellow Liquid/Greasy Substance*** (CRX Lee)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX Lee &raquo;</TD></TR><TR><TD CLASS="quote">Wipe the oil down at the top and check the rate at which the oil is returning but I do think it is likely that the O-ruing under the adjuster tab is leaking a bit if it returns. Although I can't see volume, that does look like shock oil.
Wipe 'em down and check the rate of return. If it comes back pretty quickly, contact Bob or Stoney in Koni Tech at 859-586-4100 option 6 and it would be good to have a copy of your purchase receipt and registration available to get the ball rolling. </TD></TR></TABLE>
thanks. i was talking to Stoney yesterday.....i just gotta fax my ish there. i just made this post to make sure it was really a leak of some sort. anywho, thanks again!
Old May 10, 2006 | 09:14 PM
an2ny888's Avatar
i think the girl in the avatar is leah dizon, correct me if im wrong
Old May 10, 2006 | 10:16 PM
jli18's Avatar
Default Re: ***Koni Yellow Liquid/Greasy Substance*** (an2ny888)
yea ur right, i want to see her naked so bad, does anyone have pictures of her nudity?
Old May 11, 2006 | 02:04 PM
ecahatch's Avatar
Senor Miembro
Default Re: ***Koni Yellow Liquid/Greasy Substance*** (jli18)
so.....ya about that leak.
Old May 11, 2006 | 05:25 PM
__oversea's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jli18 &raquo;</TD></TR><TR><TD CLASS="quote">yea ur right, i want to see her naked so bad, does anyone have pictures of her nudity?</TD></TR></TABLE>
i've seen it..lol long time ago. dont remember anymore.
ya about that leak, glad koni has good service as usual
Old May 11, 2006 | 05:27 PM
ecahatch's Avatar
Senor Miembro
k, this seems to be going OT.......so if a mod sees this. please lock. THANKS!
Old May 14, 2006 | 12:49 AM
thahuhstunna's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ECAhatch &raquo;</TD></TR><TR><TD CLASS="quote">k, this seems to be going OT.......so if a mod sees this. please lock. THANKS! </TD></TR></TABLE>
haha... bump so a mod might peep it
Old May 14, 2006 | 10:59 PM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: ***Koni Yellow Liquid/Greasy Substance*** (thahuhstunna)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thahuhstunna &raquo;</TD></TR><TR><TD CLASS="quote">
haha... bump so a mod might peep it</TD></TR></TABLE>
They don't really seem to do that in here. I can't remember the last thread I saw get locked in the suspension forum...
JustAnotherRex
Suspension & Brakes
14
Nov 7, 2007 04:43 PM
95gsrhead
Suspension & Brakes
12
Dec 5, 2006 11:52 AM
DFW
Suspension & Brakes
Oct 29, 2006 11:39 AM
jlh22179tx
Suspension & Brakes
Oct 20, 2006 11:39 AM
johnzm
Suspension & Brakes
Feb 8, 2006 11:29 AM
