Problems with GSR swap.
I have a 95 2 door ls that we just finished the swap on, but we are trying to wire the Vtech and im not exactly sure what i need. I have the engine harnes, i also have a Vtech subharness, and the GSR comp. Is there anything else i should need. I got the Vtech sub harness off of Rywire.com. Any help would be greatly appreciated. thanks
You will get best results in the "HYBRID" area of this site. I have never done a swap so all i can help you with is telling you to post this as stated in previous sentence.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by acuradude2006 »</TD></TR><TR><TD CLASS="quote">I have a 95 2 door ls that we just finished the swap on, but we are trying to wire the Vtech and im not exactly sure what i need. I have the engine harnes, i also have a Vtech subharness, and the GSR comp. Is there anything else i should need. I got the Vtech sub harness off of Rywire.com. Any help would be greatly appreciated. thanks </TD></TR></TABLE>
If you have a GSR swap, you should atleast know it's spelled <u>Vtec</u>..
I just did this swap myself.I also use the subharness off rywire.This is for 94-95 obd-1 swaps.
Wired it like so.
A4-vtec solinoid-black
D3-knock sensor-white
D6-oil pressure switch
Now the secondaries varies from usdm to jdm ecu.
If its USDM Ecu-A17-Red-iab control-yellow wire goes to 12v source.Tap the yellow/black wire that leads to A25 with the yellow wire.
If your using a Jdm ecu-Red goes to A17 and you just run the yellow to chassis ground.Hope this helps.
Heres a thread on the iabs on my swap.
https://honda-tech.com/zerothread?id=1581504
Wired it like so.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Wayne_Curr »</TD></TR><TR><TD CLASS="quote">You need this Vtech computer, it'll wire right up into your swap...
