Suspension & Brakes Theory, alignment, spring rates....
Integra LS suspension vs. Civic EK suspension
Old May 9, 2006 | 09:38 AM
whuynh168's Avatar
Default Integra LS suspension vs. Civic EK suspension
Are the civic and the integra suspensive interchangable? Are the spring rates the same?
Old May 9, 2006 | 09:44 AM
Marauder's Avatar
Default Re: Integra LS suspension vs. Civic EK suspension (whuynh168)
spring rates are different.
front shocks bolt up, the rears are different.
Old May 9, 2006 | 12:14 PM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: Integra LS suspension vs. Civic EK suspension (Marauder)
Front suspension is similar, and all integra parts will bolt onto an EK. The Integra front brakes are bigger than the EK ones, and will require a larger master cylinder.
As for the rears, the EK has longer/skinnier LCAs and cannot be swaped. That also means the fork at the bottom of the EK rear shocks is skinnier, and will not swap eiither. To put the Integra rear discs on an EK with drums, you'll need the proportioning valve from any 96-00 hatchback or 99-00 Si. You will also need e-brake cables that will fit your chassis (research).
Using Integra springs on an EK, may result in an awkward ride height. You should just buy lowering springs & use your stock EK shocks...
NaturalTone
Suspension & Brakes
May 22, 2012 07:23 PM
speedking
Suspension & Brakes
Oct 8, 2009 02:01 PM
C_R_X_
Mar 15, 2009 07:07 PM
tronic
Suspension & Brakes
Mar 21, 2007 02:37 PM
Chubakon
Jun 12, 2005 12:56 AM
