d15b7 crank in a d16z6 possible?
Old May 9, 2006 | 09:26 AM
happyabortion's Avatar
Default d15b7 crank in a d16z6 possible?
can i use a d15b7 crank in a d16z6 block??would i have any comeplications??lmk really wanting to fix this car
Old May 9, 2006 | 09:39 AM
Voyage34's Avatar
Default Re: d15b7 crank in a d16z6 possible? (happyabortion)
the d15 crank has a shorter stroke than the d16 by about 5mm
while i dont know of any physical will-not-fit restrictions, i would avoid doing so simply because the shorter stroke will make your tdc piston to deck height heigh huge, lowering your compression by a bunch. stock z6 compression is 9.2:1 iirc, the d15 crank will lower it to almost 7flat:1
Old May 9, 2006 | 10:22 AM
rabius's Avatar
journal sizes are different.
short answer, no.
Old May 9, 2006 | 12:22 PM
Voyage34's Avatar
Default Re: (rabius)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rabius &raquo;</TD></TR><TR><TD CLASS="quote">journal sizes are different. </TD></TR></TABLE>
thanks for clarifying
a reason you cant not one why you shouldnt
Old May 9, 2006 | 04:32 PM
Default Re: (Voyage34)
cool thanx!!
mike93eh2
Aug 3, 2010 10:01 AM
vtec4max
Oct 26, 2009 05:28 PM
whiteturbohatch
Sep 21, 2005 03:48 PM
delslo93
Mar 18, 2005 01:26 PM
