Synthetic Oil Change Question
Old May 9, 2006 | 08:54 AM
B16Jacques's Avatar
Default Synthetic Oil Change Question
Hi guys, have a b16 just doing a synthetic oil change.
Been running with Castrol 10w30 and changing to synthetic, just wanted to know what you guys do to clean everything out before you put new oil in.
Old May 9, 2006 | 09:38 AM
88crx-si's Avatar
-add some sea foam in your engine 10-20 miles before doing an oil change.
-do the oil change.
-do the oil change again at 1500 after switching to synthetic.
-continue with regular oil change intervals with synthetic.
thats what i did when switching to synthetic. i never used any other kind of automotive additive or cleaner other than sea foam. it can be used in the gas tank, injection, and crankcase. there are alot of people who recommend sea foam and some who dont, but i do.
Old May 9, 2006 | 09:43 AM
B16Jacques's Avatar
Default Re: (88crx-si)
thanks, for the info
Old May 9, 2006 | 09:52 AM
RCautoworks's Avatar
Default Re: (B16Jacques)
Just change oil, no need to clean out the engine.
By the way, I hate seafoam. Why, search and you will see the problems
Old May 9, 2006 | 12:01 PM
PURPLETERROR aka BIGMATT's Avatar
Default Re: Synthetic Oil Change Question (B16Jacques)
just change the oil
Old May 9, 2006 | 05:53 PM
jacoop86's Avatar
Default Re: Synthetic Oil Change Question (PURPLETERROR aka BIGMATT)
when i swiched to synthetic i just let the old oil drain for like 45 minutes, and did the same thing on the next oil change. probably didnt do much good but i wanted to get as much conventional oil out as possible.
Old May 9, 2006 | 05:58 PM
Crx Jimmy's Avatar
Default Re: (90blackcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90blackcrx &raquo;</TD></TR><TR><TD CLASS="quote">Just change oil, no need to clean out the engine.
By the way, I hate seafoam. Why, search and you will see the problems </TD></TR></TABLE>
yeah just drain and put in the new stuff, or if you want to clean out the motor before you put it in run some marvel mystery oil in it for a couple hundred miles thats what the local honda dealer uses for cars brought back on lease before they sell them. cleans out all the old gunk from the asshats going 10,000 miles on an oil change cause the car is leased
Old May 9, 2006 | 06:14 PM
StorminMatt's Avatar
Default Re: (Crx Jimmy)
There's no need to do anything special when going from conventional oil to synthetic. Just change it. Although you don't want to mix conventional oil with synthetic in large quantites, the relkatively small amount of old oil that is already in there is not going to cause a problem.
Old May 9, 2006 | 07:04 PM
LSVTEC 91 Civic's Avatar
Banned
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16Jacques &raquo;</TD></TR><TR><TD CLASS="quote">Hi guys, have a b16 just doing a synthetic oil change.
Been running with Castrol 10w30 and changing to synthetic, just wanted to know what you guys do to clean everything out before you put new oil in.</TD></TR></TABLE>
FYI.. Castrol Syntec is not a synthetic oil.. just a highly refined dino.
If you want to run a good FULL synthetic, run Castrol 0w-30, and make sure it says "Made in Germany" on the back of the bottle. It is excellent oil.
07FG2
Honda Civic (2006 - 2015)
41
Feb 9, 2009 05:58 PM
GsDAteg
Dec 15, 2008 01:01 AM
Behan
Sep 9, 2003 05:10 AM
NewR
Apr 28, 2002 06:25 PM
TypeR01-424
Aug 17, 2001 07:51 AM
