JDM ITR Fender Brackets?
I've never herd of these.. would i have a problem if i didn't have them for my JDM conversion?
http://www.passwordjdm.com/pro...D=213
No, you won't. I think they're completely useless. You can actually bend ur stock and make it work. But there won't be much of a difference even without it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kuja »</TD></TR><TR><TD CLASS="quote">No, you won't. I think they're completely useless. You can actually bend ur stock and make it work. But there won't be much of a difference even without it. </TD></TR></TABLE>
Ok cool - i just wanted to make sure i get everything i need for the conversion. PasswordJDM makes it sound like its a necessity, so i wanted to make sure before i blew an extra 50 bucks
ive installed fronts with and without the brackets..i would recommend buying a set..the fenders are mounted a lot more solid with them..without it it relies on only the headlights to mount to they are bit flimsy and a little harder to get a clean bumper to fender fit
..worth the 45-50 dollars imo
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SINFULintegXsi »</TD></TR><TR><TD CLASS="quote">ive installed fronts with and without the brackets..i would recommend buying a set..the fenders are mounted a lot more solid with them..without it it relies on only the headlights to mount to they are bit flimsy and a little harder to get a clean bumper to fender fit
..worth the 45-50 dollars imo</TD></TR></TABLE>
Thanks - thats exactally what i needed to know
Frostwhite_DB8
Sep 13, 2007 09:06 AM
EP3-R
Nov 17, 2003 03:06 PM
