another way to install axles?
Old May 9, 2006 | 05:02 AM
chile's Avatar
Default another way to install axles?
i can't get the front lca separated from the steering knuckle to put these bitches back in...is there another way to re-install the axles on my 90 integra? searched but didn't find what i was looking for...thanks all.
Old May 9, 2006 | 05:15 AM
CleanLikeJdm's Avatar
Hype-R Stalker
Default Re: another way to install axles? (chile)
Disconnect the upper control arm and pull the hub/brakes towards you.
Old May 9, 2006 | 05:21 AM
chile's Avatar
Default Re: another way to install axles? (FlatBlackTeg)
thanks, i'll try that...
Old May 9, 2006 | 05:30 AM
Hype-R Stalker
Try?? what, you thinking it won't work??
I've never done it by disconnecting the LCA, so it def works.
Just take out the one bolt on the UCA, then of course you need to split it,
but after that you just pull back the hub setup, put the axle into the trans first then into the hub.
Old May 9, 2006 | 05:31 AM
chile's Avatar
i said try cause my dumbass may expletive that up, too...
Old May 9, 2006 | 05:39 AM
Hype-R Stalker
haha, well, do you have that Fork like tool to split apart a joint?
That's all you need, along with a Big hammer, plus it's a lot more assessable then the LCA.
Old May 9, 2006 | 06:41 AM
projectTeG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FlatBlackTeg &raquo;</TD></TR><TR><TD CLASS="quote">Disconnect the upper control arm and pull the hub/brakes towards you.</TD></TR></TABLE>
yup this will work, just pop the UCA balljoint and pull it down.
Old May 9, 2006 | 12:44 PM
chile's Avatar
Default Re: another way to install axles? (projectTeG)
worked beautifully...thanks, guys.
Old May 9, 2006 | 01:36 PM
Orangecivic251's Avatar
cool you got it
halocore
Jul 25, 2008 08:52 PM
Arsenal
Sep 12, 2005 10:31 AM
mongoliandonuts
30
Feb 15, 2004 09:51 AM
ghettols
Aug 22, 2003 11:57 AM
guttedhatch
May 28, 2003 08:09 AM
