Bone stock 1/4 mile times
Curious to what others have run. Here in the hot and humidity of Tampa Bay (84 degrees) I was able to pull out a 14.1 @ 96mph with 2.1 60ft. Stock 16's, Fusion Zri's...no idea what tire pressure was (didn't check). Drove to the track, ran the **** out of it, drove it home.
The key is in the launch...I side stepped the clutch at 6000, 6500, and 6700. No problems. She fishtailed a little, but got out of the hole pretty good all things considering. This is a 2001 with 48k miles.
After doing this, I know a stock s2000 is capable of 13's.
What have you run?
What have you run?
60ft - 2.0810
330ft - 5.9089
1/8th ET - 9.0930
1/8 MPH - 76.96
1/4 ET - 14.1372
1/4 MPH 97.28
This is on a stock 2002 S2000 79000 miles with fuzion Zri's tire pressure was set at 20psi and side stepped at 7500
To put these #'s into comparison I had a Turbo Acura LS that trapped 108 and would usually run about 13.00-13.20 in the 1/4 and the 1/8 et was 8.5 and the MPH in the 1/8 was 86
330ft - 5.9089
1/8th ET - 9.0930
1/8 MPH - 76.96
1/4 ET - 14.1372
1/4 MPH 97.28
Here's a video of two of my runs. I am the red s2k going against the 350z
http://video.google.com/videop...19977
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FR-MOB: Projekt »</TD></TR><TR><TD CLASS="quote">13.68 @100</TD></TR></TABLE>
bone stock? slicks or anything?
so with a good driver you can hit 13's all day long?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SilverDc2-Ap1 »</TD></TR><TR><TD CLASS="quote">so with a good driver you can hit 13's all day long?</TD></TR></TABLE>
very possible but key is the driver
The hardest part by far is the launch. I just don't find myself launching the S2000 like I would for any other car I have driven. Still, I need some work on my launches. Nice times guys
