Where can I get LCA's at for my DA??
Old May 8, 2006 | 11:35 PM
T
Default Where can I get LCA's at for my DA??
Okay I am wondering what companies make lower control arms for the DA chassis?? Will EG or DC2 LCA's fit on there??? Any help would be great.
Old May 9, 2006 | 06:22 AM
iakona's Avatar
any DC/EG lca will fit, but you will ahve to get some turnbuckle style links for the sway bar to mount up. i have funtion7 and they work great.
Old May 9, 2006 | 08:03 AM
MJobe's Avatar
Default Re: (iakona)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iakona &raquo;</TD></TR><TR><TD CLASS="quote">any DC/EG lca will fit, but you will ahve to get some turnbuckle style links for the sway bar to mount up. i have funtion7 and they work great.</TD></TR></TABLE>
WTF? please explain more i am intrested in the same thing
Old May 9, 2006 | 08:26 AM
iakona's Avatar
comptech actually sells teh best kit, and i will pick one up later, but you need to correct teh sway bar mounting position. it is off around 1.5" or so to the outboard side of the lca. because the geometry is diff. b/t the DA and the DC/EGs. the turnbuckle is basically a link that has spherical bearings at the end that allows the link to sit sideways, but still function properly. the comptech kit is kind of expensive (like 65 per set if i remember right), but well worth it as it adds an extra joint so there is less stress on the lower joint of the turnbuckle.
i'll try and take a pic later, but here's the links i am talking about.
but the new function7 arms dont' need it, as they have mulitple holes now.
here's the Comptech link without the extra hinge point kit:
and the link kit installed: notice the driver side and the way it mounts.
Old May 9, 2006 | 08:31 AM
iH8RICERZ's Avatar
Default Re: Where can I get LCA's at for my DA?? (H22Hatchie)
ebay has a lot of different lca's for all types of cars...last time i checked. Just go with the brands you can trust...
Old May 10, 2006 | 10:40 AM
djbutler007's Avatar
David I need to to get in touch with me asap
Old May 12, 2006 | 10:28 AM
DavidR's Avatar
The best kit? Function7 has an adjustable endlink kit as well, and its cheaper than $65 per side!! Heck, its under $65 for the entire thing! You know what to do.
Old May 12, 2006 | 02:41 PM
00IntegrAllmotoR's Avatar
HT Black OPs
Default Re: (DavidR)
SPC FTW
...esteban
Suspension & Brakes
Sep 17, 2007 05:30 AM
-Championship-
Feb 21, 2007 01:25 PM
JDM_EjONE
Jul 11, 2006 08:58 AM
BIGGIDYBOB
Nov 17, 2004 05:50 PM
