Emissions and Smog experts! I still need your help!
Please check out my thread linked here to the Accord forum if you know anything about how to lower Carbon Monoxide CO emissions! I have searched and made good use of the info here, but I am on my 5th retest and could use any expert advice...
https://honda-tech.com/zerothread/1621792
Remove ur pcv valve to create a vac. leak just before u go. Also, locate ur evap canister and follow that line that goes to the intake, remove it from the canister. Leave the timing retarded and ull get ur pass.
let me know how that goes, Dan
Good info, that trick will ONLY work on a healthy, well tuned and maintained engine and some...
Modified by hazw8st at 10:00 AM 6/5/2006
caibang88
Mar 3, 2008 08:28 PM
