Anyone heard of this coilover before?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99FBPSi »</TD></TR><TR><TD CLASS="quote">What are those little allen wrench screws for?</TD></TR></TABLE>
Those are there to hold the sleeve in place, so you can adjust the perches. Usually the coilovers come with different plastic or rubber sleeve spacers that go over the shock. You then tighten up the allen screws to anchor the sleeves.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG6_GUY »</TD></TR><TR><TD CLASS="quote">Those are there to hold the sleeve in place, so you can adjust the perches. Usually the coilovers come with different plastic or rubber sleeve spacers that go over the shock. You then tighten up the allen screws to anchor the sleeves.</TD></TR></TABLE>
Ok I get it now. It basically clamps on to the strut?
no
Ok I get it now. It basically clamps on to the strut?</TD></TR></TABLE>
no
it keeps the perch from spinning down, which isn't likely to happen in the first place on GC's
no
no
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slammed_93_hatch »</TD></TR><TR><TD CLASS="quote">it keeps the perch from spinning down, which isn't likely to happen in the first place on GC's</TD></TR></TABLE>
no
Those screws have nothing to do with the perches. I don't even see allen screws on the perches(maybe the quality of the pics is too low). These coilovers use two perches tightened against each other to hold the spring at a set height. This is nothing like a Ground Control single perch setup.
no
no
Those screws have nothing to do with the perches. I don't even see allen screws on the perches(maybe the quality of the pics is too low). These coilovers use two perches tightened against each other to hold the spring at a set height. This is nothing like a Ground Control single perch setup.</TD></TR></TABLE>
my mistake, i didn't think that he would still be intereted in those POS coilovers
no
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slammed_93_hatch »</TD></TR><TR><TD CLASS="quote">my mistake, i didn't think that he would still be intereted in those POS coilovers</TD></TR></TABLE>
Hopefully he passes on those and saves his scratch for something better.
Honissan
12
May 4, 2004 03:20 PM
