need help with REV-LITE
have any of you guys intalled the REV-LITE in your teg?
if you have, how did you wired it? did you follow the web-site's instructions?
where did you guys get the signal from?
thanks for your help.
From the website:
Simple 3 wire hook up
Rev-Lite has only 3 wires to hook up. Simple connections for:
1)12 volt power (via your accessories circuit in the fuse box)
2) earth to the cars chassis
3) tacho signal, usually from the negative terminal on your ignition coil. If you own a multi coil car you will only need to locate the tacho signal from your computer which will be avalible either from the wiring loom near the computer itself or from the ign power module
You might try reading the instructions.
thanks dude,
i just think the run to the - terminal is kind of long. i was hoping that maybe somebody in here had picked up the signal from a different poing. no biggy,
if i have to run it to the coil oh well............
thanks again
thanks again
slowteg550
Jul 13, 2006 07:26 PM
95accordracer
Jun 9, 2003 06:52 PM
