Are all 88-89 doors lighter than 91s?
Old May 8, 2006 | 08:14 PM
wfocrx's Avatar
Default Are all 88-89 doors lighter than 91s?
Iam trying to lighten up me 91 dx crx some and have heard that the 88-89 crx doors are lighter due to the lack of the door mounted belts. Is it just the interior door panel and belt that makes it weight 10-15lbs heavier per door? Any 88-89 crx door would fit a 91' crx right?
Old May 8, 2006 | 08:19 PM
crxnj's Avatar
Default Re: Are all 88-89 doors lighter than 91s? (wfocrx)
yes its true,, the doors with the seatbelts mounted on them are alot heavier..they have a steal beam/frame inside the door....
not sure if the 88 or 89 crx door will fit the others,,never tried it..but i heard the 88 door is different...again im not sure
Old May 8, 2006 | 08:27 PM
wfocrx's Avatar
I thought I heard that you can use 88-89 doors on a 90-91; but not the other way around. I did a search and found a post where some guy got rid of the door mounted bolts but had to do welding and other diy stuff. If I have to do all that it isn't worth it.
Old May 8, 2006 | 10:02 PM
90JDMEF8's Avatar
They ARE lighter but i dont think they will line up because the 90-91's have a thicker C-Pillar on the door to support the heavier seat belt and the 88-89's dont... but it MIGHT work...
Old May 9, 2006 | 12:21 AM
_Keith_'s Avatar
Well its not a crx but I took 88 doors and put them on my 91 hatch just had to unbolt the door holders at the top that the 91 came with.
intense_imports
Mar 31, 2007 09:09 PM
661rex89si
Oct 2, 2006 02:43 PM
joeyblow
Oct 2, 2005 02:41 PM
dtown_racer
Feb 21, 2005 04:35 AM
B2FiNiTY
20
Dec 13, 2003 09:46 AM
