MPFI swap on a 91 civic... final questions then READY TO ROCK
ok, so the new 1.6l is in, and i'm doing the wiring. heres my last question...
all (3 of em) of the mpfi swap instructions that i have talk about how the distributor should have 2 empty plugs to hook up the Multi Port Crank Angle Sensor... refers to it as an "Si DIstributor" so i look at the one that was on the 1.6L motor, and its only got 1 unused plug... so i think, ok i need to buy an SI distributor. so i go onto ebay to look for this distributor, and its EXACTLY the same as the one that was on the 1.6... so uhh, wtf do i do?
how the heck do i hook up this crank angle sensor????
bump.. gotta have this thing running by the end of the week...
anyone have pictures or ANYTHING they can say to help me?
did you look at this one ? scroll towards the bottom,,i used this writeup and had no problems
http://crf50.no-ip.com/fourthgenhatch/mpfi.html
you can just use the square plug and just solder the two extra wires together. or just find a round si plug and do it that way.
yeah i used that site too.
the problem is that the tutorials say there should be two unused pins, but there is only one on the plug... they all say that one of the wires at the connector will be blue with a green stripe, the other will be blue with yellow stripe -- but neither exist.
wtf am i missing?!
wtf am i missing?!
bump.. someone has to have had the same issue as this.... any help??! none of the how-to's have the answer!
ef9king
Feb 9, 2006 01:34 AM
Tw1n Turb0 Z
May 10, 2005 06:08 PM
saltyblue
Mar 17, 2005 08:35 AM
89 CRX SI
27
Jan 20, 2003 04:12 PM
