ITR i/h/e dyno (VID)
Old May 8, 2006 | 08:08 PM
itr1244's Avatar
Default ITR i/h/e dyno (VID)
the number's really low. 164 hp and 121 tq
here's the graph. any comment would be appreciated.
the a/f reader was at the tail pipe . so it's not that accurate
here's the video
<A HREF="http://media.putfile.com/integra-type-r-dyno
" TARGET="_blank">http://media.putfile.com/integra-type-r-dyno
</A>
Old May 8, 2006 | 11:09 PM
A.E Motoring's Avatar
Default Re: ITR i/h/e dyno (itr1244)
link dont work
Old May 9, 2006 | 01:18 AM
Dirtfall's Avatar
and your picture is so bright i cant read it
Old May 9, 2006 | 03:46 AM
rainmanEK's Avatar
big strong guy
Default Re: ITR i/h/e dyno (Dirtfall)
Why are you saying the A/F reader was ot accurate?
Eric
Old May 9, 2006 | 08:17 AM
itr1244's Avatar
Default Re: ITR i/h/e dyno (rainmanEK)
you guys might have to use the direct download thingy
a/f ratio is not accurate becuase the senser was mounted at the tail pipe
Old May 9, 2006 | 11:37 AM
jamessh1's Avatar
which header, intake, exhaust? who knows, the dyno may just read low, but did you get any tuning done?
Old May 9, 2006 | 04:07 PM
itr1244's Avatar
Default Re: ITR i/h/e dyno (jamessh1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jamessh1 &raquo;</TD></TR><TR><TD CLASS="quote">which header, intake, exhaust? who knows, the dyno may just read low, but did you get any tuning done?</TD></TR></TABLE>
An-R header, prototype V stack, 2.5" B-pipe + Mugen TL and Busted/clogged up carsound cat
for comparson.
stock Coblat SS 205whp 195tq.
stock 01 S2000 197whp 130tq.
str4 mopar stg.1 238 whp 305 TQ
Old May 9, 2006 | 04:44 PM
kangaroo's Avatar
damn i hope i can pull at least 175whp on my jdm itr motor with i/h/e.
Old May 9, 2006 | 04:56 PM
brokeHonda's Avatar
Default Re: (kangaroo)
Old May 10, 2006 | 05:18 PM
Tomcat's Avatar
You need to retain a CAT w/ the OBD 2 setup. Try another racing CAT in good condition, and possibly a Comptech chipped OBD 2 ECU for some added flexibility; and then re-test.
Old May 10, 2006 | 05:54 PM
itr1244's Avatar
Default Re: ITR i/h/e dyno (Tomcat)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tomcat &raquo;</TD></TR><TR><TD CLASS="quote">You need to retain a CAT w/ the OBD 2 setup. Try another racing CAT in good condition, and possibly a Comptech chipped OBD 2 ECU for some added flexibility; and then re-test. </TD></TR></TABLE>
car's running obd1 ecu
Old May 17, 2006 | 05:16 PM
Tomcat's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr1244 &raquo;</TD></TR><TR><TD CLASS="quote">
car's running obd1 ecu </TD></TR></TABLE>
Sorry for the delayed response, I've been busy with work. Look over your setup; is there anything that you would perceive as being a potential bottle-neck? I've heard of stock ITR's posting numbers like that on baseline runs, but usually not with an after-market I/H/E setup like you have.
We can't read your dyno graph; does it look like there is fuel starvation in the upper RPM range? Have you had a leak-down test done recently? It could simply be a dyno issue also, as stated earlier.
s2kb0i
Honda S2000
Oct 5, 2006 08:36 AM
Skelly
Aug 7, 2005 10:07 PM
blackntegra
Apr 20, 2005 07:08 AM
Tw1n Turb0 Z
15
Jan 9, 2004 02:58 PM
KriLYu
Oct 3, 2003 10:27 PM
