D16Z6 in 88HF - Greddy Kit
I'm dropping a D16Z6 into my 88 CRX HF, I am planning on going the turbo route, and was looking into the Greddy kit. Will this kit even fit in the CRX, I know it will fit the motor fine and everything, just didn't know if there were any clearance issues etc. when that motor is installed in the Rex. I don't mind if I have to make my own intake piping or something, or get the exhaust custom made to fit up to the turbo, just want to know if there are any major problems with this setup in a CRX (installation wise). And if it doesn't work, are there any kits that DO work, or is custom the only way to go. Thanks a lot.
As far as I have heard- the kit bolts right in with the exception of the charge piping- If condenser fan clearance is an issue- you can mount one in front of the condenser. The downpipe will bolt right up to your exhaust. Just be sure to use the Z6 intake manifold and ECU- You may have to trim the front crossmember some. I plan on going greddy on my Z6.
[Modified by fixhondas, 6:59 PM 4/10/2002]
vmsturbo
Aug 26, 2004 10:57 PM
