*sigh* My car is feeling ill...........
When I stop and put it in first itll start to stall.... Started 2 weeks ago. At first I thought my dumbass was off the clutch, but nope...... Bleh.
My ignition keyhole thingy keeps getting stuck. Stuck meaning, Ill take the key out--yet the car will act like its still in there IE: When door opens, itll beep... Cant use keyless entry Blah blah. I gotta stick the key in again to get it unstuck. I checked it and its clean, like nothings stuck in there.
My gas gauge thing....... Driving to projekts house usually takes up less than 1/5 tank. Well, not really but something like that. Basically--Not too much. On Sunday morning before Eibach..... My tank was full. I go to projekts and Im down to almost half a tank! So I fill up there, head to Autobacs-then irvine-then Corona..... After the meet projekt and I head to Garden Grove for lunch.. Then I go back up to LA... Thats almsot 200 miles.... I think. And I still have 3/4 tank left. GRR!!!!!!!!
My car is dying. Is it because Im not buying him enough Mugen? Should I get more??
HAHA just kidding! Seriously though, this sucks. I work 72+hrs a week, so I dont think I have time to take him to the stealership either.
PS: AND I lost my bumper plugs. GRR!x2
My car is dying. Is it because Im not buying him enough Mugen? Should I get more??HAHA just kidding! Seriously though, this sucks. I work 72+hrs a week, so I dont think I have time to take him to the stealership either.
From: A place where stupidity runs rampant aka NorCal
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FR-MOB: Beb »</TD></TR><TR><TD CLASS="quote">When I stop and put it in first itll start to stall.... Started 2 weeks ago. At first I thought my dumbass was off the clutch, but nope...... Bleh. </TD></TR></TABLE>
My car did the exact same thing when my dumbass forgot to plug the vtec solenoid back in after I changed the oil. Took a few revolutions of turning the car on, driving it and shutting it off until it was behaving normally again. Doesn't seem to be your problem (unless you did the same thing recently....), but it was the same symptom.
-Todd
-Todd
PS: AND I lost my bumper plugs. GRR!x2</TD></TR></TABLE>
Is the car actually using up all that gas or is the guage not reporting the correct level? When you filled up, did you fill up 5+ gallons when it showed half full?
It sounds like your instrument cluster is acting up since it controls the beeping when the door is ajar and the key is still in the ignition as well as the fuel level (duh). You could have a short somewhere in the electical system. Any recent modifications?
reset the ECU maybe? kinda like resetting your computer when it screws up. my car was being kinda buggy so i pulled the plug and everthing worked great after that.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vapor »</TD></TR><TR><TD CLASS="quote">Is the car actually using up all that gas or is the guage not reporting the correct level? When you filled up, did you fill up 5+ gallons when it showed half full?</TD></TR></TABLE>
Gauge aint right.
I just found my receipt for the gas... After projekts I put in 2.9 gallons. That seems about right for the distance to his house...... But my gauge was reading a little over 1/2 tank full, and we all know an S does not have a 6gal tank.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">It sounds like your instrument cluster is acting up since it controls the beeping when the door is ajar and the key is still in the ignition as well as the fuel level (duh). You could have a short somewhere in the electical system. Any recent modifications? </TD></TR></TABLE>
No recent mods.....
Maybe my car is just throwing a tantrum so I buy it more presents.
Or:
(11:19 AM 5/9/2006) FR-MOB: Chubzilla: beb i think your s2 has the bird flu
(11:32 AM 5/9/2006) FR-MOB: Beb: Really? I was leaning more towards SARS.......
(11:33 AM 5/9/2006) FR-MOB: Chubzilla: no, it might have an STD
Serious note-- Bleh. I guess Ill just have to find time somehow to go to the dealership. Work PWNZ me but itll be better than running out of gas at night in LA while my gauge reads full or something. =T
Gauge aint right.
I just found my receipt for the gas... After projekts I put in 2.9 gallons. That seems about right for the distance to his house...... But my gauge was reading a little over 1/2 tank full, and we all know an S does not have a 6gal tank. <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">It sounds like your instrument cluster is acting up since it controls the beeping when the door is ajar and the key is still in the ignition as well as the fuel level (duh). You could have a short somewhere in the electical system. Any recent modifications? </TD></TR></TABLE>
No recent mods.....
Or:
Its that time of the month for your car, the car knows its a woman driver therefore gets it too!
j/k, i guess your going to have to take it in to the dealership.
This happened to me to, at first i thought the same thing i was just being dumbass and letting off the clutch.
Then i found a service bulletin that covered this subject.
PROBABLE CAUSE
During hard acceleration, engine vibrations may cause
shifting of the contacts at the MAP sensor. This may
cause wear that changes the resistance of the
connection at the MAP sensor.
CORRECTIVE ACTION
Replace the MAP sensor, and install the MAP sensor
holder.
PARTS INFORMATION
MAP Sensor and Holder Kit:
P/N 06176-PCX-000, H/C 7868599
Tie Wrap:
P/N 32125-PCX-003, H/C 7868607
NOTE: One tie wrap is included in the MAP sensor and
holder kit. A replacement tie wrap is needed only if the
MAP sensor is disconnected during a later repair.
Since i installed the map sensor i haven't felt the near stall problem.
as for the gas thing...
"Don't know, Have know Idea."
PROBABLE CAUSE
CORRECTIVE ACTION
holder.
PARTS INFORMATION
Tie Wrap:
^^ he works at honda dealership ... knows his **** and good guy ... you should go out with him Beb ... lol ... i can vouch for him
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FR-MOB #4: Jerk »</TD></TR><TR><TD CLASS="quote">^^ he works at honda dealership ... knows his **** and good guy ... you should go out with him Beb ... lol ... i can vouch for him
I dont believe in long distance relationships. lol
Thanks S Carter!!!!!!
</TD></TR></TABLE>I dont believe in long distance relationships. lol
then how come you and *ahem* (the suspension dude) still going at it!?
HAHAHAHAH
i think imma die ahead of Dang now (inside joke) ROFL
HAHAHAHAH
It's pretty bad if she's down here almost everyweekend.. and you die before me.
You wanna be buried with your car? I'll do it for u right before she kills me.
beb: I'll check out your car according to S CARTER's instructions next time i see ya.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nishant »</TD></TR><TR><TD CLASS="quote">It works now? Your car is weird. I think you aren't giving him enough TLC</TD></TR></TABLE>
I think her car got scared because I offered to work on it.
You should stay away then. If you touch it, he may blow up. Then Beb will definitely kill you and then take your S to replace hers
Meh.. Raynard and Christie are a couple. If Raynard blows up, I'm gonna drive Christie into a cliff, then crush them both into one huge metal ball and bury them...
*sniffles*
*sniffles*
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FR-MOB: Projekt »</TD></TR><TR><TD CLASS="quote">Meh.. Raynard and Christie are a couple. If Raynard blows up, I'm gonna drive Christie into a cliff, then crush them both into one huge metal ball and bury them...
*sniffles*
I would rather not see that happen, wouldn't want my first trip out to cali be for a funeral
*sniffles*
</TD></TR></TABLE>I would rather not see that happen, wouldn't want my first trip out to cali be for a funeral
No way. Dang knows that I love and care about my car a little too much actually. =T
Haha Dang!!! Its like Romeo and Juliet! At least theyll die together....... But then we'll have to buy new S's......
And all theyll have is 06! Booo!!!!!!!
yes, you need my mugen 2.2l header.
My car is dying. Is it because Im not buying him enough Mugen? Should I get more??</TD></TR></TABLE>
