1992 accord EX
its my dads old car, and he hasnt done crap to the car besides maintenance and a nice sound system. what can i do to get it running like new/better than new besides swapping the engine? it has 240,000 miles... automatic transmission, sedan..... ????
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KillerElfboy »</TD></TR><TR><TD CLASS="quote">You could put another timing belt in it, that basically calls for an engine rebuild which is always great for the car.</TD></TR></TABLE>
What? Changing a timing belt is changing the timing belt. It's far from an engine rebuild. It may not be due for changing, depends when it was changed last. All I would advise you to do is keep up the maintenance.
Proper maintenance will help you out. Performance wise i wouldnt do anything to a motor of that high mileage. You can but i just wouldnt. You could do a full rebuild of your motor and try to drop a turbo thats the closest thing i can think of without doing an engine swap and such.
You could get it rebuilt and shave the head for some more compression, plus do a P&P.
You'd end up with 165-170 at the crank. not bad if it's gonna need a rebuild at some point soon.
Not sure how much cheaper than a swap though.
Take the intake manifold off and clean it good, will help alot with the performance of the vehicle also might want to change the timing belt because its an interference motor. also while the intake manifold off clean the egr ports. It will save you some problems down the road. And good luck.
jus2sho
67
Sep 6, 2006 06:17 PM
e_r_i_c_
Apr 22, 2003 07:02 PM
dclub01
Mar 19, 2003 08:34 AM
Bubble Gum Jr.
Jan 2, 2003 12:20 PM
