Can you tell me what these connectors are?
Old May 8, 2006 | 03:23 PM
god.loves.ugly
Guest
Posts: n/a
Default Can you tell me what these connectors are?
this is from the wire harness on a b18c1 which is in an 01 ls integra.
the plug is on the passenger side strut tower
wires are red and yelloww/ black
Modified by so.dark.the.con.of.man at 7:06 PM 5/8/2006
Modified by so.dark.the.con.of.man at 9:04 PM 5/8/2006
Old May 8, 2006 | 05:07 PM
god.loves.ugly
Guest
Posts: n/a
Default Re: Can you tell me what these connectors are? (so.dark.the.con.of.man)
bump help please
Old May 8, 2006 | 05:47 PM
dannylDAsport's Avatar
where is the connector located at... what part of the engine is the picture of the connector located... engine bay pix would help...
Old May 8, 2006 | 06:03 PM
IN VTEC's Avatar
It's believe it's junction C104/C220 with a Red wire (GND to ECU A20) and a Ylw/Blk (12VDC+ to the distribution block on the driver-side shock tower) for the EVAP purge solenoid on GS-R motors ONLY.
Old May 8, 2006 | 06:22 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IN VTEC &raquo;</TD></TR><TR><TD CLASS="quote">It's believe it's junction C104/C220 with a Red wire (GND to ECU A20) and a Ylw/Blk (12VDC+ to the distribution block on the driver-side shock tower) for the EVAP purge solenoid on GS-R motors ONLY.</TD></TR></TABLE>
If it is the EVAP purge control solenoid valve, on the B18C1 engine, then the corresponding number would be C117, middle of engine.
Old May 8, 2006 | 07:00 PM
IN VTEC's Avatar
Default Re: (tech8)
C117 is where the engine harness connects to the EVAP purge solenoid. C104/C220 is where the engine harness (for the EVAP purge solenoid) meets the chasis harness on the passenger-side shock tower.
Old May 8, 2006 | 07:02 PM
god.loves.ugly
Guest
Posts: n/a
Default Re: Can you tell me what these connectors are? (dannylDAsport)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dannylDAsport &raquo;</TD></TR><TR><TD CLASS="quote">where is the connector located at... what part of the engine is the picture of the connector located... engine bay pix would help...</TD></TR></TABLE>
its on the passenger side strut tower I do not have any pictures of the engine by since I'm at work now but I will try to post some if it will help.
Old May 9, 2006 | 04:05 AM
god.loves.ugly
Guest
Posts: n/a
More pics. Bump for help.
since I am using the GSR motor harness what do I need to be able to connect this to where it needs to go.
Old May 9, 2006 | 04:08 AM
god.loves.ugly
Guest
Posts: n/a
Default Re: (IN VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IN VTEC &raquo;</TD></TR><TR><TD CLASS="quote">C117 is where the engine harness connects to the EVAP purge solenoid. C104/C220 is where the engine harness (for the EVAP purge solenoid) meets the chasis harness on the passenger-side shock tower.</TD></TR></TABLE>
so since I have the LS chasis harness is there anything I can do besides buy a gsr chasis harness?
Old May 10, 2006 | 08:00 AM
utahbmx's Avatar
Bump it up for help.
raidacaipo
May 12, 2008 08:07 PM
sleeping beauty
Jul 4, 2004 05:17 PM
hondacrx90
Jun 1, 2004 06:35 AM
Morhpeous
May 30, 2004 05:33 PM
yOnKiNaToR
Feb 18, 2004 06:57 PM
