Think I'll get into 13's?
Going to the track on Friday... Pretty pumped. I went there before I was boosted and ran a 16 flat with 2.4 60' times. I had no idea how to launch at that point. This time I'm shooting for 2.1-2.2 60's on 17" Wheels and tires...
Engine:
Stock 96 LS motor with 143k
Spoolin Performance Mani+2.5"DP
Garret T3/T04e 57 trim .63 a/r
SSAC 38mm Wastegate, 55mm BOV, 24x8x3 FMIC
2.5" Aluminized IC pipes
Street tuned on Uberdata for 9 psi
Suspension:
Eibach Sportlines
205/40/17 Yokohama Parada spec-2s.
I'm doing the run with full interior, on street wheels and tires. This is in my Integra LS chasis, at 9 psi. Anyone want to venture a guess as to what ill run? I'm hoping to break into 13's but I'm having doubts because of my big wheels.
Modified by Kowalski at 6:56 PM 5/8/2006
Engine:
Suspension:
Eibach Sportlines
Depends on your driving ability. You can go 13's easily with 100mph traps. I went 13.97 with 99mph traps with horrid 2.3 60' fts. ion a GSR hatch. Then I went 13.7's @ 101 with 2.1 60' fts. in a GS-T. When you go to the track, if you're trapping 100mph+, the car is capable of 13's.
Should be able to hit 13's since your tuned and boostin 9psi, I ran 14.0 98mph on 7psi stock integra with ls motor untuned and fried rings.
EVIL Hx Coupe
15
Mar 26, 2005 05:16 PM
