best chain????
Old May 8, 2006 | 12:32 PM
rusted_eyes's Avatar
Default best chain????
what is the best chain to get? bought one a month ago from Northland Motorsports and now it's already trashed! they told me it was a cheap bad chain and now I need a new one!
I have a 94 Honda CBR600F2 it's a 525 chain what is the best brand/type?
NORTHLAND MOTORSPORTS
Old May 8, 2006 | 12:41 PM
EngineNoO9's Avatar
Default Re: best chain???? (rusted_eyes)
what do you mean trashed? rusted up, stretched, broken??
Old May 8, 2006 | 12:43 PM
Veritas-Aequitas's Avatar
Grumpy Old Man
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rusted_eyes &raquo;</TD></TR><TR><TD CLASS="quote"> bought one a month ago from Northland Motorsports and now it's already trashed! they told me it was a cheap bad chain and now I need a new one!</TD></TR></TABLE>
Was it made of tin cans or something?
expletive them, I'd be pissed!
I'm no chain connoisseur but I'd think that most the of the major brands are pretty much the same depending on what strength you want to go for and assuming you don't care much about weight.
Old May 8, 2006 | 02:15 PM
marmaladedad's Avatar
I've used RK (or was that EK?) and DID chains with no problems whatsoever.
Hope the crap-chain didn't mess up your sprockets.
Old May 8, 2006 | 08:05 PM
rainmanEK's Avatar
big strong guy
Default Re: (marmaladeboy)
I just got the "RK XW-RING (GXW)" It wasnt to much more then the Normal X ring, So I said F*&# It!
Eric
Old May 8, 2006 | 10:50 PM
Snaps's Avatar
Default Re: (rainmanEK)
AFAM
Old May 9, 2006 | 06:59 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by marmaladeboy &raquo;</TD></TR><TR><TD CLASS="quote">
Hope the crap-chain didn't mess up your sprockets.</TD></TR></TABLE>
yeah me too, should i just get a package w/sprocket and chain? and upgrade to the 520?
The RK/Vortex 520 Race Conversion Kit can reduce rotating & unsprung weight by over 3 lbs! Features a VORTEX 7075 T6 Ultra-Lite aluminum rear sprocket and drilled Gold chromoly steel front sprocket. Comes with an upgraded RK 520XSO RX-ring Gold chain Chain Included: GB520XSO-108
Old May 9, 2006 | 07:03 AM
If your sprockets are still new, then you can get away with buying only a chain. Otherwise, I highly recommend replacing both at the same time. Sprockets that are worn out will wear a new chain out faster than normal. Same applies to new sprockets and an old chain.
I haven't noticed a real difference in the longevity of my chain when using different a 530 or 520.
Old May 9, 2006 | 07:28 AM
TXcivic96's Avatar
QUOTE=rainmanEK]I just got the "RK XW-RING (GXW)" It wasnt to much more then the Normal X ring, So I said F*&# It!
Eric [/QUOTE]
x2, This is the chain I use, if it wasnt this one it would be the DID ERV2 or ERV3,
Old May 9, 2006 | 08:29 AM
EngineNoO9's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by marmaladeboy &raquo;</TD></TR><TR><TD CLASS="quote">If your sprockets are still new, then you can get away with buying only a chain. Otherwise, I highly recommend replacing both at the same time. Sprockets that are worn out will wear a new chain out faster than normal. Same applies to new sprockets and an old chain.
I haven't noticed a real difference in the longevity of my chain when using different a 530 or 520.</TD></TR></TABLE>
where'd you get your 520 kit? I have to change mine in a month or so
Old May 9, 2006 | 12:14 PM
Default Re: (EngineNoO9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EngineNoO9 &raquo;</TD></TR><TR><TD CLASS="quote">where'd you get your 520 kit? I have to change mine in a month or so</TD></TR></TABLE>
Same place I get most of my other stuff - Terra Powersports.
Old May 9, 2006 | 01:17 PM
EngineNoO9's Avatar
haha alright
Old May 9, 2006 | 01:32 PM
TEST ONLY's Avatar
Default Re: (rusted_eyes)
The RK/Vortex 520 Race Conversion Kit can reduce rotating & unsprung weight by over 3 lbs! Features a VORTEX 7075 T6 Ultra-Lite aluminum rear sprocket and drilled Gold chromoly steel front sprocket. Comes with an upgraded RK 520XSO RX-ring Gold chain Chain Included: GB520XSO-108</TD></TR></TABLE>
[b] 520 Conversion!
Old May 10, 2006 | 07:44 AM
Default Re: (hazw8st)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hazw8st &raquo;</TD></TR><TR><TD CLASS="quote">
[b] 520 Conversion!
yeah just ordered mine!
chinoty
Welding / Fabrication
Jul 16, 2005 10:34 AM
senpai
Audio / Security / Video
Oct 6, 2004 02:48 PM
Nerologic
May 4, 2004 03:07 PM
Rising sun #1
Jun 17, 2003 02:47 PM
