Suspension & Brakes Theory, alignment, spring rates....
front sway bar es bushing
Old May 8, 2006 | 10:43 AM
byronl's Avatar
Default front sway bar es bushing
hey guys i was lookin under my 93 civic ex and saw that the front sway bar bushings were pretty much done. I was wondering if I change the bushings to some energy suspension ones if it would be worth it. I currently have agx shocks lowered on neuspeed springs, would I feel a difference in the front with new bushings?
Old May 8, 2006 | 11:33 AM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: front sway bar es bushing (byronl)
You should be able to feel the difference over worn stock bushings. The only reason I wouldn't necissarily recomend poly is because they are squeeky. Especially in the sway-bar area. If this is a factor for you, you should probably just order new OEM rubber...
dgerej2
Suspension & Brakes
May 21, 2010 05:55 AM
Got Utensils
Suspension & Brakes
Feb 25, 2007 07:22 PM
silverCRXTC
46
Feb 18, 2004 08:24 PM
