Suspension & Brakes Theory, alignment, spring rates....
no bumpstops
Old May 8, 2006 | 09:30 AM
EF mark's Avatar
Default no bumpstops
what will happen if i cut my bumpstop to the last notch or if i take them out completly?
Old May 8, 2006 | 09:58 AM
EF mark's Avatar
up
Old May 8, 2006 | 10:29 AM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: (EF mark)
Never run less than 1 full inch of bump stop. They are an integral part of your suspension system. Without them, you will destroy your shocks, and possibly damage suspension arms and your chassis...
Old May 8, 2006 | 12:02 PM
EF mark's Avatar
ok my ef in the back is high doesnt even looked lowered so if i cut my bump stop down to 1 inch it should lower it a bit right my coilovers are at the lowest setting
Old May 8, 2006 | 01:42 PM
RaceCarRyne's Avatar
i run without them all the time.. who cares.. struts aint that expensive ne wayz
Old May 8, 2006 | 02:24 PM
94eg!'s Avatar
#1 Super Guy
Loved
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF mark &raquo;</TD></TR><TR><TD CLASS="quote">ok my ef in the back is high doesnt even looked lowered so if i cut my bump stop down to 1 inch it should lower it a bit right my coilovers are at the lowest setting</TD></TR></TABLE>
When you lower your car, your supposed to cut your bump-stops down...
Old May 8, 2006 | 06:17 PM
Black Paper Diary's Avatar
Where can i buy some bump stops for my '97 integra? I searched and only found a place for civics. Are they the same?
Old May 8, 2006 | 08:09 PM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: (Black Paper Diary)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black Paper Diary &raquo;</TD></TR><TR><TD CLASS="quote">Where can i buy some bump stops for my '97 integra? I searched and only found a place for civics. Are they the same?</TD></TR></TABLE>
http://www.acuraautomotiveparts.org
Old May 9, 2006 | 09:52 AM
EF mark's Avatar
why you thread highjacking
i took apart my suspension and i dont even have bump stops in teh back what now?
Old May 9, 2006 | 10:47 AM
94eg!'s Avatar
#1 Super Guy
Loved
I don't quite understand your problem. First you say you want to cut/remove the bump stops, then you say you don't have them...
Please list all your suspension mods, what brands of parts you have (OEM & aftermarket), etc...
Old May 9, 2006 | 11:56 AM
EF mark's Avatar
ok i took apart my suspension and it doesnt have bumpstops i have ebay coilovers which came with the car and stock shocks i just want the lowest setting and i have seen people cutting bumpstops
Old May 9, 2006 | 12:06 PM
94eg!'s Avatar
#1 Super Guy
Loved
Well if your coil-over is set all the way down the sleeve, and your car doesn't look lowered at one end, then you probably have the springs on the wrong ends of the car.
And for god sakes man, get some bump-stops...
Old May 9, 2006 | 12:10 PM
EF mark's Avatar
springs where the same size
Old May 9, 2006 | 12:30 PM
94eg!'s Avatar
#1 Super Guy
Loved
Are you sure. Sometimes they may have the same number of coils, but one pair may have thinner wire than the others. If that is the case, then the thinner ones should go in the rear.
If the wire is the same thinckness but there are a different number of coils, then the pair with fewer coils goes in the front.
If both pairs of springs are identicle, then you will have exactly the problem your describing. You can't do anything about it unless you buy new springs. Ebay coilovers are crap, so what do you expect...
marauder228vw
Mar 22, 2012 07:02 PM
marauder228vw
Mar 13, 2012 05:50 PM
bsclywilly
30
Jul 8, 2008 01:15 PM
HipHop Head
Feb 10, 2006 04:17 PM
Rob.
Suspension & Brakes
Sep 10, 2005 04:45 AM
