Y1 grinding.
Old May 8, 2006 | 07:33 AM
bseriesEF's Avatar
Default Y1 grinding.
i just got a new clutch and synchros. still grinding 3 and 4. i was told that y1's will always grind but shifting 3rd can be difficult sometimes especially at high rpms. any suggestions? i thought about just buying a new gear altogether, but would that solve the problem?
Old May 8, 2006 | 07:44 AM
Pnoyej6's Avatar
* B A N N E D *
Default Re: Y1 grinding. (bseriesEF)
i grind 2nd gear on my crx si. not sure why. Do i need to replace mtf?? or brake fluid
Old May 8, 2006 | 09:07 AM
blumpfish's Avatar
Default Re: Y1 grinding. (pnoytegn707)
puttin in synchromesh might temporarily get rid of the grinds, it worked for me so far.. put on about 1kmiles with no grinds yet
Old May 8, 2006 | 09:25 AM
bseriesEF's Avatar
Default Re: Y1 grinding. (blumpfish)
i thought about that, but is that all you can do to get rid of it?
Old May 8, 2006 | 10:07 AM
Pnoyej6's Avatar
* B A N N E D *
DO I PUT ALL SYNCROMESH OR HALF MTF. WHICH ONE DO REPLACE THE BRAKE FLUID FOR THE CLUTCH TRANNY FLUID. HOW DO I DRAIN FLUID AND WHERE DO I FILL UP TRANNY FLUID?? wHERE IS THE CONTAINER . IM NEW TO CRX .
Old May 8, 2006 | 12:00 PM
blumpfish's Avatar
thats pretty much all you can do without opening up the tranny
i wouldnt put half mtf in cus its a different weight oil then syncromesh..
Old May 8, 2006 | 02:05 PM
looxs's Avatar
GM syncromesh w/ friction modifier is around $13 a bottle and i need about 2.3 bottles to fill right??
Andyxramirez
Mar 19, 2013 03:07 PM
red5FWD
Jan 27, 2008 07:43 PM
viva60
Feb 19, 2006 12:43 PM
FLCivic
10
Apr 14, 2004 07:19 PM
metal-x
Sep 13, 2002 09:47 AM
