Suspension & Brakes Theory, alignment, spring rates....
Is there a specific order in which you remove the bolts from the fork and control arms so you dont m
Old May 8, 2006 | 06:17 AM
streetracerof06's Avatar
Default Is there a specific order in which you remove the bolts from the fork and control arms so you dont m
I am doing a swap for the second time and last time I did my swap one of the shocks locked up and I was told that if you dont take off the bolts that hold the upper and lower control arms and fork in place off in a certain order than it will mess up the shock. I was wondering what order the bolts and nuts need to be taken off. Thanks.
Old May 8, 2006 | 10:15 AM
Tyson's Avatar
Default Re: Is there a specific order in which you remove the bolts from the fork and control arms so you do
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by streetracerof06 &raquo;</TD></TR><TR><TD CLASS="quote">I was told that if you dont take off the bolts that hold the upper and lower control arms and fork in place off in a certain order than it will mess up the shock. </TD></TR></TABLE>
um no, not really.
i usually just remove the bottom shock bolt, then fork pinch bolt to remove the fork. then remove the brakelines. take off the two 14mm top nuts and remove...
no big deal.
Old May 8, 2006 | 01:16 PM
Thanks
pearl
Sep 6, 2004 11:37 PM
CrazyKoreanCrx
Apr 18, 2004 06:10 PM
Dseriespower
10
Dec 7, 2003 08:09 PM
^Sammy]!.
Sep 22, 2003 05:47 PM
