Smoking prob
Old May 8, 2006 | 05:59 AM
djstain's Avatar
Default Smoking prob
I am having a problem with my GSR i have CAI, DC 4-2-1 header, everything else is stock, i realize my car is skoking excessively, white smoke and i notice my oil level decreses as the days progress, my coolant hasnt moved so i am really worried, have any checks i could do
Old May 8, 2006 | 07:16 AM
DC2 Mang's Avatar
Default Re: Smoking prob (djstain)
do a leak down test
how many miles are on it?
sounds like your rings and going bad
Old May 8, 2006 | 07:27 AM
djstain's Avatar
Default Re: Smoking prob (JDMdc2lsVtec)
engine jus installed last year 1998 sir engine 50k miles
Old May 8, 2006 | 07:39 AM
skunked's Avatar
how is the temp? Does the exhaust smell "sweet" like coolant?
Old May 8, 2006 | 08:11 AM
Smash03's Avatar
Hmmm....often times ppl mistaken blue smoke as white smoke because you can barely tell. From what you're sayin, it shouldn't be white smoke. It's most likely blue smoke if you're burning oil. Can you tell where the oil leak or where the smoke is comin from?
Old May 8, 2006 | 08:29 AM
ForceFed Motorsports's Avatar
Do you even PLEBE R8?
White smoke is coolant... check it again and make sure its not blue, which is oil.
Old May 8, 2006 | 08:35 AM
Sijray21's Avatar
are you noticing any oil in the coolant resevoir?
Old May 8, 2006 | 08:57 AM
gurgle's Avatar
When does it smoke? After starting or idling for awhile, or all the time? Worse when you get on it?
Color/smell? Like someone said earlier, steam and oil smoke are often confused. If there's kind of a sickly sweet smell to it, then you're losing coolant. You said you checked that though, so I'll trust you.
Does sound like your rings are bad. Can you do a compression test?
Old May 8, 2006 | 02:33 PM
dc5_integra's Avatar
If it is smoke it will float around in the air, be blueish color and smell really bad. If it is water it will be white and disipate into the air very quickly.
Old May 8, 2006 | 03:55 PM
PLAGUED_DB7's Avatar
valve seals going out....
Old May 9, 2006 | 04:03 AM
djstain's Avatar
I notice int the morning's when i start it and it idle's 4 a while i seel white smoke i was watching it this morning my mech telling me it can be brake fluid running back in the IM, he said it cannot be my rings cauz engine is basically new, not sure wat to check first but i will keep u guys posted
Old Jun 1, 2006 | 09:21 PM
mylsspecteg's Avatar
i am having basically the same problem. I just put new pistons and rings into my b18a and its smoking still ater 400 miles. Its def losing oil out the tailpipe. Coolant level is good and never gets hott.
Old Jun 1, 2006 | 09:58 PM
turbodegsi's Avatar
just because it is an sir motor with 50k on it doesn't mean it's good. how was it stored before you got it. were all holes that go into the motor blocked off so no moisture can get in. i have noticed on these honda motors that if they sit for a long time with no cover on the ports they tend to burn oil. rings could get sticky or cylinders could get rusty from moisture causing rings to go bad prematurely. just a thought...
hadden
11
Aug 7, 2013 10:57 AM
blackmfoggie
Sep 7, 2007 07:34 PM
bosco500
13
Oct 3, 2005 06:12 AM
1990civicsi
Aug 8, 2004 06:33 PM
extrmeboost
Jun 13, 2003 08:00 AM
