12.5 ef four door
well i took my scaper to a test and tune at sac (track suck no VHT but still doing 1.7 60s ft) car weighs 2100 248hp on a dyno pack let me know you guys think! Thanks
http://vids.myspace.com/index....1&n=2
Modified by ISPhuevos at 4:09 AM 5/13/2006
247hp174 dynopack
SET-UP/ car was open header tune on 100 octane
RedZone built -
84mm B18A1 block
IBspec Wiseco's 11.3:1
Probe rods
Polished and balanced rotating assembly
ACL Bearings
hondata gasket
hondata s200
Type-r oil pump
Fadanza flywheel
RedZone Stage 3 clutch
ITR Transmission
B17A ported by a friend in LA
Super-tech Valves
Super-tech Springs and retainers
440cc injectors
Blox Type
-B Cams
JG Cam gears
Blox intake manifold Port match
68mm RPM TB port matched
255LPH-HO in-tank fuel pump
SMS copies headers 4-2-1
vtec at 4800rpm
RedZone built -
84mm B18A1 block
Probe rods
ACL Bearings
hondata gasket
hondata s200
Type-r oil pump
Fadanza flywheel
ITR Transmission
Super-tech Valves
440cc injectors
Blox Type
-B Cams
JG Cam gears
vtec at 4800rpm
nicely done, props to a sedan running 12's, if you rolled up next to me, i would never expect a sedan to be that fast, and after we take off, id be like holy **** i just got smoked
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ISPhuevos »</TD></TR><TR><TD CLASS="quote">car weighs 2100</TD></TR></TABLE>
Is that about normal? Is the int stripped? Just curious about the weight on the 4 drs.
Hondaswap says:
1991 Honda CRX DX MT 2103
1991 Honda CRX HF MT 1967
1991 Honda CRX Si MT 2174
1991 Honda Civic DX HB MT 2165
1991 Honda Civic Si HB MT 2291
1991 Honda Civic HB MT 2127
1991 Honda Civic DX SDN MT 2262
1991 Honda Civic LX SDN MT 2322
1991 Honda Civic EX SDN MT 2374
Not too much more, but I believe that there's more weight you can pull from the interior of the sedan than you can from a crx/hatch. If you want to go crazy, you could cut a crapload of rear skeleton (trunk for instance) to save a lot, just for instance.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gen2fanatic »</TD></TR><TR><TD CLASS="quote">what a badass car dude
do you drive that thing on the street, or is it just strickly track??</TD></TR></TABLE>
just track only i use to drive but i lost my driver license
here are some pic when i was cutting the weight
Before
After
i did a custom wire harness took me 3 mouths because i didnt knew **** about wiring but i still have to clean up under the dash
Modified by ISPhuevos at 1:33 AM 5/11/2006
Before
After
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wickedEFguy »</TD></TR><TR><TD CLASS="quote">This is a dumb question but what kind of wheels are on those slicks?</TD></TR></TABLE>
Lenso
Lenso
I only wish my had no rust.
