boucy tach after mpfi conversion
Old May 7, 2006 | 11:15 PM
Hung_Lo's Avatar
Default boucy tach after mpfi conversion
I just did an mpfi swap on my 89 civic cx.
I noticed that after about 4000+rpm the tach starts to get real bouncy. As in the tach starts to wander around after 4000 rpm.
I changed the gauge cluster and still the same problem.
Any suggestions?
Old May 8, 2006 | 12:48 AM
1QuikSOHCZC's Avatar
Default Re: boucy tach after mpfi conversion (Hung_Lo)
check ur dizzy. my buddies hatch woulkd pull great until he got in upper rpms. 4000+ then it would like missfire kinda and u could see the tach kinda bounce everything is did that. he open up his dizzy cleaned it out and it turned out he ignitor connections were loose. so he tighted all the stuff in the dizzy down the clips on the ignitor n such and got a new rotor n Cap and his car was running great spent 25 bucks instead of 150+ for a new dizzy..
Old May 8, 2006 | 02:08 AM
slywfbpsi's Avatar
Default Re: boucy tach after mpfi conversion (1QuikSOHC)
Yeah, mine did that too. Come to find out the rpm signal wire in the dizzy was not connected to the terminal. It was just sitting next to it. Reconnected it, and all was well.
hatch_dude
Jul 16, 2010 06:54 PM
quicksilver1689
Oct 23, 2008 11:14 PM
Fatcobra
Apr 17, 2007 05:20 AM
frostee trooper
Feb 6, 2005 10:58 PM
StupidSlowRSX
Dec 24, 2003 02:12 AM
