difference between f22b1 head and f23a1 head?
Old May 7, 2006 | 07:04 PM
hybridpatient95's Avatar
Default difference between f22b1 head and f23a1 head?
im wondering if there is any difference between the f23a1 and f22b1 cylinder heads.. i know both are vtec.. but would the combustion cc's and the cam profile be the same ?
also what head studs would i need to use to put this head on my f22a1?
Old May 8, 2006 | 02:49 AM
drhrde
Old May 8, 2006 | 05:05 AM
notoriousB's Avatar
Default Re: (hybridpatient95)
H23 head studs will work for an F23 head to F23 block I don't see why they wouldn't work on F23 head to F22A block.
Old May 8, 2006 | 12:25 PM
Default Re: (notoriousB)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by notoriousB &raquo;</TD></TR><TR><TD CLASS="quote">H23 head studs will work for an F23 head to F23 block I don't see why they wouldn't work on F23 head to F22A block.</TD></TR></TABLE>
thanks man..
now would there be a difference like internaly that seperate the 2 head? like ports and cam profiles?
Old May 8, 2006 | 12:37 PM
TypeRobert's Avatar
bump cus i wanna know if cams are more aggresive too i read on sumother thread tht the F23 intake mani flows better and is a direct bolt on to F22 head correct?
Old May 8, 2006 | 06:26 PM
Default Re: (TypeRobert)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TypeRobert &raquo;</TD></TR><TR><TD CLASS="quote">bump cus i wanna know if cams are more aggresive too i read on sumother thread tht the F23 intake mani flows better and is a direct bolt on to F22 head correct?</TD></TR></TABLE>
well i mnow the manifold flows better because the design of it is more like the h22/h23 manifolds.. but idk bout the bolt right on part.. i think the ports/ there locations look alittle off
Old May 9, 2006 | 04:59 AM
notoriousB's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybridpatient95 &raquo;</TD></TR><TR><TD CLASS="quote">now would there be a difference like internaly that seperate the 2 head? like ports and cam profiles?</TD></TR></TABLE>
F23 intake and exhaust ports are layed out differently than the F22A ports. F22A manifolds will not bolt up to an F23 head.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TypeRobert &raquo;</TD></TR><TR><TD CLASS="quote">the F23 intake mani flows better and is a direct bolt on to F22 head correct?</TD></TR></TABLE>
I don't know about flow but the F23 will direct bolt up to an F22B head, but not an F22A.
FYI - another monkey wrench for you guys, the F23A IM uses a 3 wire IACV, where the F22 uses a 2 wire IACV. If you make the IM swap you will have to figure out an adapter plate to mount your 2 wire IACV to the F23 IM.
-B
Old May 9, 2006 | 10:43 AM
they make the adapter plates for the 3 wire iacv to 2 wire.. its like 35 bucks.. no biggie
95accord3267
Jul 28, 2011 05:56 AM
pinoy_93cb7
Jul 6, 2011 01:29 PM
PreLuder96
May 3, 2009 05:58 PM
1BADEGDC2
Feb 17, 2008 09:56 AM
SlammedCD7
Jul 17, 2005 11:36 PM
