removing front bumper
Old Apr 10, 2002 | 11:05 AM
1320Motorsports's Avatar
Default removing front bumper
My brother just got some jdm headlights but we are having a problem removing the front bumper....if anything we cant get to the plastic gromets that are under the headlight housing. There are two under each one and we cant get the headlight housing out to get to these. Any suggestions?
Old Apr 10, 2002 | 11:17 AM
Nick H's Avatar
New User
Default Re: removing front bumper (1320Motorsports)
what year accord is it? i think there is a recent post about removing this with some pics as well...it's the 5th gen i believe...search for it and see what you can find!
Old Apr 10, 2002 | 11:22 AM
Default Re: removing front bumper (nickh2k1)
its a 5th gen also. Any help espcially pics will help a lot, thanks!
Old Apr 10, 2002 | 11:25 AM
SOHCArchangel's Avatar
oh man this is going to be a pain
you must loosen the stock headlights to get at the plastic screws under the headlights...
Old Apr 10, 2002 | 12:02 PM
John's Avatar
New User
Default Re: removing front bumper (SOHCArchangel)
when you reinstall the bumper cover, might we recommend that you leave out the screws from underneath the headlights... they're really not essential to have, and are more of a pain in the *** than anything else....
Old Apr 10, 2002 | 12:09 PM
Default Re: removing front bumper (DunReit)
yeah, yeah, yeah, wut he said I forgot that one
Old Apr 10, 2002 | 04:43 PM
greensleeper's Avatar
yeah man i just did this a few weeks ago.. I actually thought for a short time that I was supposed to break the seal on the headlight cover to be able to remove the damn things... fortunately I realized how unnecassary they are and I used a utility knife to cut off the head of the clips.
good luck with that by the way. once you take a bumber off it never seems to go back on the same way....
Old Apr 10, 2002 | 05:34 PM
CD8's Avatar
CD8
Default Re: removing front bumper (greensleeper)
1. one 10mm bolt at corner of bumper inside wheel well.
2. remove bumper lights
3. 2 12mm(i believe) bolts behind each side.
4. bumper will fall on you, just taking out those 6 bolts will remove the bumper... you have no need to take out those damn platic things...
takes me 15min to take off/put on my bumper.
[Modified by exaccord, 6:35 PM 4/10/2002]
Old Apr 10, 2002 | 10:36 PM
Default Re: removing front bumper (exaccord)
thanks for the help guys...we finally got that bastard off and got the headlights in.
if i remember correctly there is an 8mm bolt on each side in the fender well, a plastic screw grommet under each corner light, 6 of those damn grommets, two more where the bumper lights are that screw upwards, and a few screws on the bottom that screw to that plastic lining to the fenders....or at least thats the ones that were on his car.
The jdm headlights look pretty damn good. Ill post some pics soon as i get a few pics of them
Old Apr 11, 2002 | 01:09 PM
H22a Type S and SHit's Avatar
I have a 92 accord and i gotta do the same to install my new headlights housings, but last time i tryed, i got the two screws off the left and right fenders, but thoses dam platic clips wouln't come off, i tryed to unscrew them and then i end up braking all four under the car~!!!!! any help on taking them off????
Old Apr 11, 2002 | 01:12 PM
well i can take off my front bumper under a minuite now....as i need to take it off everytime i need to jack it up from the front
Old Apr 11, 2002 | 02:26 PM
CD8's Avatar
CD8
cant you just slide in the oem jack on the side and lift the car enough with that to clear the front... thats what i do.
Old Apr 11, 2002 | 02:33 PM
Accord94DX's Avatar
Same here
XaznKewLguyX
Dec 31, 2006 05:02 AM
cyb3rjak
Mar 26, 2005 05:46 PM
accordsil2
Jun 17, 2003 05:53 AM
JdmAcclude
Feb 18, 2002 07:36 PM
